yella 90 Posted July 9, 2009 Share Posted July 9, 2009 as the title says whats the best/easiest way to fit the auto box to my td5 what do i need to do and what not to do please, this needs be a idiots guide as im a virgin to auto's Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 9, 2009 Share Posted July 9, 2009 Take it and your chequebook to Mr Ashcroft - best and easiest Quote Link to comment Share on other sites More sharing options...
ashtrans Posted July 9, 2009 Share Posted July 9, 2009 Bogmonster you are very kind, thought I would pipe up as we are doing loads of Defender auto kits at the moment for big V8's, TD5's and 2.4 TDCi's there are a few ways to do this, starting with the cheapest : 1) get from a 300 disco auto : autobox, shifter & trim then from a TD5 disco get : TD5 bellhousing, torque converter, starter ring, boss, flexplate, oil cooler and pipes, hi/lo mounting bracket (FRC8558) 200 tdi disco diff lock lever stick this lot together and make up a linkage off the throttle pedal to pull the kickdown cable, you can buy one of our neat centre consoles if you want to make it look pretty, pros : cheap cons : have to hunt about, won't drive great 2) from a TD5 disco get : autobox with bellhousing, torque converter, starter ring, boss, flexplate, oil cooler and pipes, hi/lo mounting bracket (FRC8558) 200 tdi disco diff lock lever buy from us : compushift console (optional) pros : will drive nice cons : if the autobox is OK ! 3) buy the lot from us pros : will drive nice, no looking for parts, just wave credit card cons : autobox will be OK !, 4) let us supply and fit pros : will drive nice, no looking for parts, just wave credit card (even more) cons : cost 5) option 3 and 4 but with stage 1 or 2 autobox upgrades and converter upgrade. conclusion, forget 1, the compushift is the way to go, only consider 2, 3 or 4, only 5 if you are flush and the box will be working very hard hope this helps, theres more on our web site or email me if you need any more help, Quote Link to comment Share on other sites More sharing options...
yella 90 Posted July 9, 2009 Author Share Posted July 9, 2009 dave, im the guy who had a natter with you the other day then ended up purchasing compushift from you it'll all be stitched together this weekend, ive got everything from a disco 2 ready to fit together, i was just asking on whats the easiest way to fit the box + what to watch out for when fitting cheers dan Quote Link to comment Share on other sites More sharing options...
JST Posted July 9, 2009 Share Posted July 9, 2009 excellent reply Dave, says it how it is from a top company. Quote Link to comment Share on other sites More sharing options...
smo Posted July 9, 2009 Share Posted July 9, 2009 Wait for dave to reply with the "fitting procedure", sadly i fitted mine before someone told me the technique and mine might be bust...or might not! I got my compushift from dave too - very helpful chap, im just longing to get it all finished and get driving again. Quote Link to comment Share on other sites More sharing options...
