love2learn Posted July 10, 2009 Share Posted July 10, 2009 the rear prop where it goes into the differential unit does the shake rattle and roll. i cant be arsed to do the uj change thing im running out of time (holidays commin up) so if i just buy a replacement is it just pull it off and push the new one on? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 10, 2009 Share Posted July 10, 2009 I don't know what you mean by "pull and push" ans the prop is held on with bolts!! If you buy a new prop it is simply a case of unbolting the old and bolting on the new. You might want to invest in new nylocs for the propshaft bolts. Be sure to chock the wheels before taking the prop off or put it in diff lock with the handbrake on! Quote Link to comment Share on other sites More sharing options...
love2learn Posted July 10, 2009 Author Share Posted July 10, 2009 thanx what i meant was pull out the old one and push on a new one . Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2009 Share Posted July 10, 2009 thanx what i meant was pull out the old one and push on a new one . No, you need to undo and do up 4 bolts per flange Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 10, 2009 Share Posted July 10, 2009 No, you need to undo and do up 4 bolts per flange Err.... with a possibility of a hint of "rive off 4 badly rounded and seized nuts and 4 stretched bolts per flange, throw away, replace with new items correctly torqued up; seek medical attention for skinned knuckles" Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 10, 2009 Share Posted July 10, 2009 And if you mean the diff pinion is loose, rather than the propshaft UJ, then you need to replace that not the prop. Quote Link to comment Share on other sites More sharing options...
