bimotaman Posted July 13, 2009 Share Posted July 13, 2009 hi there im new to this forum and looking for some help on a gearbox problem on my 3.5efi 86 rangie. i recently changed the box in my rangie due to the last one failing. i changed it with a unit from a 89 3.9efi complete with torque converter. i drove the doner vehicle home so i knew there were no problems with it. i carefully removed the box and changed the transfer box with one of a defender to lower the ratio for bigger wheels. however on removal i snaped the kickdown cable. on fitting the box into the new car i took care to make sure the torque converter was correctly fitted and added a larger oilcooler due to fitting a winch in place of the original. anyway, back to the problem. i started the car checked fluid levels and went for a test drive, the car selects first,reverse and drive correctly however when in drive the car will not change gear and stays in first. could this be because the kickdown cable is not connected? any help or advise would be appreciated, thanks phill Quote Link to comment Share on other sites More sharing options...
dan-hicko Posted July 13, 2009 Share Posted July 13, 2009 Ive got a very similar issue with my auto box, i went to a play day yesterday and went through some water, on the way home it started to leak fluid, then i stopped for a few minutes and it developed a leak from the bell housing, then wouldn't change out of first, then to top it off i lost reverse !! . Left it overnight, thoroughly jetwashed every inch of the vehicle, took it out for another drive, it would't change out of first gear for roughly a mile, then all was fine, but leak still persists. Sorry bimotaman but i can't help you as i haven't found a cure to mine yet, will post if i do manage to get it to work through the gears from cold. Dan. Quote Link to comment Share on other sites More sharing options...
Dave W Posted July 13, 2009 Share Posted July 13, 2009 Driving the box without a kick down cable is a bad idea and will cause all sorts of problems. It's used for more than just kick down and I'd be concerned about the damage you may have done inside the box when you snapped the cable. When you replace the cable you'll be able to check the internal mechanism for any obvious signs of damage. Quote Link to comment Share on other sites More sharing options...
bimotaman Posted July 14, 2009 Author Share Posted July 14, 2009 thanks for the replys i only drove it half a mile so hopefully i have not damaged it. i will be replacing the cable later and report back Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 14, 2009 Share Posted July 14, 2009 In case it helps, they are also fussy about fluid levels. I know you say you checked it (they must be idling in neutral from memory) but where things have been moved around it may have bled some air through the system now and dropped a bit. Quote Link to comment Share on other sites More sharing options...
andyb Posted July 14, 2009 Share Posted July 14, 2009 ^^^ you need to 'cycle' them thru the gears as well to pump the fluid all round the box. Quote Link to comment Share on other sites More sharing options...
bimotaman Posted July 14, 2009 Author Share Posted July 14, 2009 thanks guys i did the cycle through the gears when testing fluids and was actually surprised how much it took, had to go out and get more!! got the new cable today but weather was against me so ill try again tomorrow Quote Link to comment Share on other sites More sharing options...
bimotaman Posted July 17, 2009 Author Share Posted July 17, 2009 thanks for everyones input. changed the kickdown cable and oil filter, now she runs like a dream! Quote Link to comment Share on other sites More sharing options...
steve_d Posted July 18, 2009 Share Posted July 18, 2009 I love a happy ending. Steve Quote Link to comment Share on other sites More sharing options...
3947mart Posted August 3, 2009 Share Posted August 3, 2009 Ive got a very similar issue with my auto box, i went to a play day yesterday and went through some water, on the way home it started to leak fluid, then i stopped for a few minutes and it developed a leak from the bell housing, then wouldn't change out of first, then to top it off i lost reverse !! . Left it overnight, thoroughly jetwashed every inch of the vehicle, took it out for another drive, it would't change out of first gear for roughly a mile, then all was fine, but leak still persists.Sorry bimotaman but i can't help you as i haven't found a cure to mine yet, will post if i do manage to get it to work through the gears from cold. Dan. Sorry for the delay in posting a response....... I wasn't able to get my registration confirmed... First thing is that water will destroy the linings on the friction plates and unless you have the Kevlar bands the bands as well This broken down material will cause a sludge that blocks the valve body, fluid lines and filter leading to mass destruction internally..... Look for Pink fluid, if it's pink then a strip down is required Quote Link to comment Share on other sites More sharing options...
