Quick confirmation....
bishbosh
I am in the midst of wiring in an external "bitch switch" for my front winch and just need to confirm that the three wires I need to piggy back on the solenoid (albright) are:
- In
-Out
- Positive
Is that correct?
Ta muchly :)
Charles, you have earth to middle pin, and two switched lives to the other two terminals, 99.9% this is how I wired it up :)
Connect the switch to feed 12V to one or the other outside terminals for in/out depending on position, and as the centre terminal is earthed already there is nothing else to connect :)
So take a 12V fom the solenoid to the switch, and the switched outputs to the outside terminals, job done.
Hope that makes sense :)
Oh, they don't, but here goes again :)
Take a 12V feed to the switch and connect the switch outputs to the outer terminals of the bank of 3 on the solenoid.
So to answer original Q, yes, you need in, out, +ve.
+ve to input to switch
'in' to output pin of switch one way
'out' to output pin of switch the other way.
Centre pin of Albright is grounded.
*cough* If you have difficulty now, then I'd be worried! :D
Oh, yes it does! :P It is an external switch, not one of the dash switches!
Wow! I got some electrickery right!! :i-m_so_happy:
Thanks everyone.
