Inline 2 pin plugs/sockets for spot lamps
GL88
Does anyone know where I can get hold of the standard 2 pin pairs of plugs and sockets as used on the Geunine Parts - Safari 5000 spots (and presumably the others too)? They have 'AMP' moulded into them and latch together. I thought I'd kept a link having once found them on the web but no amount of Googling or searching this forum seems to be producing the goods.
Thanks, none of those I think (though difficult to check Tyco on iPhone on a train). I'll see if I can post a decent photo later but will need to break out the SLR. And will probably end up going with super seal.
Hi,
I used the ones from Vehicle Wiring Products:-
Like the attached.
Hope this helps.
Scrumps
  • 2 weeks later...
I picked up a couple of Freelander-1 Auxilliary Lamp Wiring Kits at a Sortout and they have Delphi Sealed Metri-Pack 150 Series Connectors to connect to the Lamps.
The female connectors on the loom look like this -
They also have a Grey Terminal Lock on the back of the Connector (not shown in this image)
The male connectors on the Land Rover lamps should look like this -
I've not yet found anywhere in the UK selling sensible quantities of these Delphi Connectors.
I intend to adapt the Freelander Wiring Kit to use to fit Hella Driving Lamps on my Discovery-2, and if I can't find Delphi Metri-Pack Connectors here in the UK, I'll replace them with AMP/Tyco Superseal Connectors, which are far more available.
  • 2 months later...
... if I can't find Delphi Metri-Pack Connectors here in the UK, I'll replace them with AMP/Tyco Superseal Connectors, which are far more available.
Answering my own question, I've found a supplier of Delphi Sealed Metripack 150 Connectors, along with almost everything else Delphi.
They're USA based and ship from there, but have a UK website in pounds, shillings and pence :unsure: , here -
http://gb.mouser.com/Interconnects/Automotive-Connectors/_/N-1ehb5/
They don't sell connector sets, only the component parts, so reference to the Delphi catalogue is essential.
Delphi Automotive Connector catalogues can be downloaded, in .pdf format, here -
http://connectors.delphi.com/automotive/
