mmgemini Posted March 24, 2006 Share Posted March 24, 2006 Well my rear door lock seems like it's died. I can't lock it now. I think the door and catch are still adjusted as they should be .... I've cleaned most of the sand out and lubricated it. Now I can move the key a fraction and the key goes solid. Are they repairable??? I eat rat poison mike I cab cause troiuble in an empty house !!! Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2006 Share Posted March 24, 2006 The lock barrel is replaceable, with the whole lock assebly off the door you should see a small pin, insert the key & depress the pin & withdraw the lock barrel as in the picture below Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 24, 2006 Author Share Posted March 24, 2006 The lock barrel is replaceable, with the whole lock assebly off the door you should see a small pin, insert the key & depress the pin & withdraw the lock barrel as in the picture below Barrel not a problem. The lock it'self is.... I eat rat poison mike I can cause trouble in an empty house !!! Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2006 Share Posted March 24, 2006 The lock it'self is.... New lock time then as the casing is rivetted/swagged together part number is MUC1030 upto VIN 314267 ---------------or 395037 from VIN 314268 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 24, 2006 Author Share Posted March 24, 2006 New lock time then as the casing is rivetted/swagged together part number is MUC1030 upto VIN 314267 ---------------or 395037 from VIN 314268 So what's the chances of me getting it to work again if I drill the rivets out and replace with c/s screws????? none ???........... Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2006 Share Posted March 24, 2006 So what's the chances of me getting it to work again if I drill the rivets out and replace with c/s screws????? none ???........... MMM have a go, I can send you some c/s duraliminium rivets [lots at work ] of various diameter's/lengths if you need some Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted March 25, 2006 Share Posted March 25, 2006 Hope that sorts it for you, Mike. Mine refuses to lock from outside despite the new barrel so I just carry a hitting stick in the cab. On a related note, has anyone managed to fit central-locking to a rear door lock? I'm not too fussed about remote-locking, just a button on the dash would be a boon. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted March 25, 2006 Share Posted March 25, 2006 Ive got one in the garage you can have for one beer token and the postage? I can take a picture and send it to you if you want ....(the pirtcure that is) let me know if you want it Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 25, 2006 Author Share Posted March 25, 2006 Thanks everybody. I'll wait until it's dry and I have a camera.Then I'll hqave a go. I'll let you into how if I'm successful. Ralph.I'll use c/s screws to rebuild it.That way it'll come apart again if needed. Turbocharger. I keep thinking of an electronic lock.Ideas anybody? I eat rat poison mike I can cause trouble in an empty house !! Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2006 Share Posted March 25, 2006 OK about the screws Mike. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 26, 2006 Author Share Posted March 26, 2006 Well it's done. All that southern African sand removed. All the sand filled grease removed and cleaned up. Four new screws fitted and it works. One thing..... The bit the actually makes the lock lock.Where is that hairpin spring supposed to locate. Ralph. You don't have a picture of the other side of the lock that you can post please?? I eat rat poison mike I can cause trouble in an empty house !! Quote Link to comment Share on other sites More sharing options...
western Posted March 26, 2006 Share Posted March 26, 2006 Just back from the rally it's 2331 now, will have a look when home from work Monday evening. Quote Link to comment Share on other sites More sharing options...
Jon W Posted April 22, 2006 Share Posted April 22, 2006 Just bringing up this thread again, as my rear door lock seem to be broken now. It wont lock due to the latch not staying at the top when the door is locked, and so by lifting te handle the door opens as the small catch falls down, i think it is just something inside the latch or a small spring on the small latch is meant to be attached to has come off preventing the door from staying lock either with key or from inside. Mike what screws did you use to reassemble the lock with?? As they need to be flush on the side which is up against the door. And how easy is it to drill out the metal bits which hold the lock together. Cheers Jon Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 22, 2006 Author Share Posted April 22, 2006 Just bringing up this thread again, as my rear door lock seem to be broken now. It wont lock due to the latch not staying at the top when the door is locked, and so by lifting te handle the door opens as the small catch falls down, i think it is just something inside the latch or a small spring on the small latch is meant to be attached to has come off preventing the door from staying lock either with key or from inside. Mike what screws did you use to reassemble the lock with?? As they need to be flush on the side which is up against the door. And how easy is it to drill out the metal bits which hold the lock together. Cheers Jon I've forgotten which size screws. Either 5mm or 6mm countersunk. 5mm I would suspect as I don't think I keep 6mm countersnk in my stock. HTH I eat rat poison mike I can cause trouble in an empty house !! Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2006 Share Posted April 23, 2006 Ralph.You don't have a picture of the other side of the lock that you can post please?? Sorry no I don't have a pic of the internal workings. Quote Link to comment Share on other sites More sharing options...
Jon W Posted April 26, 2006 Share Posted April 26, 2006 Right i decided it new lock time as i haven't got the time to fiddle with it at the moment and they seem cheap from paddocks. Do i need 395037 which is £19.95 or do i need STC2871 for £ 42.50. I thought they were all the same so i presume the cheaper one will fit?? Western you gave the part number MUC1030 upto VIN 314267 ---------------or 395037 from VIN 314268 Which is mine likely to be 1991 defender I have the chassis number begining SA where is the VIN number?? Cheers Jon Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2006 Share Posted April 26, 2006 VIN number IS the chassis number LR only use the last 6 digits to ident parts in EPC/parts catologues. rear door lock parts cat page x 2 Quote Link to comment Share on other sites More sharing options...
Jon W Posted April 26, 2006 Share Posted April 26, 2006 Ah excellent, no wonder i couldn't work out why my number weren't matching up. Thanks Western, i will order one now. Thanks for your help. Jon Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2006 Share Posted April 26, 2006 Happy to help Quote Link to comment Share on other sites More sharing options...
max_the_90 Posted August 13, 2008 Share Posted August 13, 2008 Thanks guys - this has been helpful to me too! Quote Link to comment Share on other sites More sharing options...
