bernie Posted July 25, 2009 Share Posted July 25, 2009 I am fitting a esbascher heater to the defender, and i want to insert a T piece into the fuel line, anyone know the size of fuel pipe, or the size in mm of T piece i require. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 26, 2009 Share Posted July 26, 2009 Fuel pipe is 8mm I/D. Les. Quote Link to comment Share on other sites More sharing options...
headhunter Posted July 26, 2009 Share Posted July 26, 2009 Which is the best fuel pipe to use, the flow or the return? John Quote Link to comment Share on other sites More sharing options...
simonb Posted July 26, 2009 Share Posted July 26, 2009 Which is the best fuel pipe to use, the flow or the return?John Tap into the return pipe to the tank. You can always just use normal "rubber" fuel lines and small hose clips. That was what was supplied with my Wabasto heater in the fitting kit... Quote Link to comment Share on other sites More sharing options...
bernie Posted July 26, 2009 Author Share Posted July 26, 2009 Any one know the internal measurement of the defender diesel fuel line, so a t piece willl fit inside. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 26, 2009 Share Posted July 26, 2009 Fuel pipe is 8mm I/D.Les. Quote Link to comment Share on other sites More sharing options...
