edwardatherton Posted March 28, 2006 Share Posted March 28, 2006 I have got some modern rubber ones and also some metal/leather type. Is one type better than the other, and if I use the leather ones should I soak them in oil first? Quote Link to comment Share on other sites More sharing options...
minivin Posted March 28, 2006 Share Posted March 28, 2006 I suppose the leather one's should be more resistant to grit and mud damage, but won't seal as well as the rubber one's. Liberal application of Petrolium Jelly to the leather should make them supple and help to make them impervious to water Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 28, 2006 Share Posted March 28, 2006 I've used both and havn't really noticed much difference. More important is what sort of condition the stub axles are in, as if they're grooved, then neither type will seal effectively! Jon Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 28, 2006 Share Posted March 28, 2006 I have got some modern rubber ones and also some metal/leather type.Is one type better than the other, and if I use the leather ones should I soak them in oil first? The leather ones will be kinder to the sealing collar, and yes they should be well soaked before use. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 4, 2006 Share Posted April 4, 2006 Liberal application of Petrolium Jelly to the leather should make them supple Oooooooooh! I know what that feels like. Bit O/T though isn't it? Les. Quote Link to comment Share on other sites More sharing options...
isuzurover Posted April 10, 2006 Share Posted April 10, 2006 I have never, ever seen any of the leather ones, and I have owned/dismantles/worked on a lot of series trucks. When did they stop making the leather ones and switch to plastic? Personally I would use the plastic ones if you have both. Quote Link to comment Share on other sites More sharing options...
