trt1617 Posted September 15, 2009 Share Posted September 15, 2009 hello all just wondering if any of you have any pics or ideas about where to mount said items on a non truck cab 90 many thanks Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 15, 2009 Share Posted September 15, 2009 Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2009 Share Posted September 15, 2009 a 4ft highlift will fit across the bulkhead behind the front seats, waffles dependent on their length could just lie on the floor with a false load carrying floor above them Quote Link to comment Share on other sites More sharing options...
trt1617 Posted September 15, 2009 Author Share Posted September 15, 2009 sorry forgot to mention i have a part external part internal roll cage fitted so there is a hoop and some rear stays kinda messing up putting them on the inside Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2009 Share Posted September 15, 2009 hi-lift could be strapped to one of the side stays if there's enough space Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 15, 2009 Share Posted September 15, 2009 Nige Quote Link to comment Share on other sites More sharing options...
zardos Posted September 15, 2009 Share Posted September 15, 2009 My solution Cut 3 squares of a standard length waffle board and they fit inside my external cage and are held on by bars welded to the inside and outside of the cage tube (only works with 38mm waffles). I did first have the bars welded to some U bolts clamped to the cage but they kept getting ripped on on trees. A 4ft Highlift will just fit back to front from bulkhead to rear door, mounted via some bolts to the wheel box. I also have a large 50mm, 1ft longer than standard on the roof. The orange ones also did a bonnet mounting system I seem to remember. Quote Link to comment Share on other sites More sharing options...
