Paddy Posted October 19, 2009 Share Posted October 19, 2009 1991 Defender 90, although I had an identical rattle on a S111 for 2 years before I sold it for the Defender, so I guess it’s a Landy trait or me !! The rattle occurs for a few seconds when moving if the engine nearly labours at low revs, dropping down a gear stops the rattle. I really should have dropped a gear before the rattle happens but sometimes when I’m day dreaming……. The rattle is somewhere in front, a solid sound (not panels), best describes as a large washer rattling between two large nuts. I’ve checked exhaust, props and pushed/pulled most things underneath and in the engine bay. Assuming its not a built in innovative warning to change gear any ideas where else to look or do I just live with it? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted October 19, 2009 Share Posted October 19, 2009 What engine did the series have and what engine does the 90 have? Pete. Quote Link to comment Share on other sites More sharing options...
tychoS Posted October 19, 2009 Share Posted October 19, 2009 1991 Defender 90, although I had an identical rattle on a S111 for 2 years before I sold it for the Defender, so I guess it’s a Landy trait or me !! The rattle occurs for a few seconds when moving if the engine nearly labours at low revs, dropping down a gear stops the rattle. I really should have dropped a gear before the rattle happens but sometimes when I’m day dreaming……. The rattle is somewhere in front, a solid sound (not panels), best describes as a large washer rattling between two large nuts. I’ve checked exhaust, props and pushed/pulled most things underneath and in the engine bay. Assuming its not a built in innovative warning to change gear any ideas where else to look or do I just live with it? Check if the exhaust is too close to solid metal somewhere. I had a similar rattle at low rpm, that could be avoided by sticking to low gears and keeping the rpm above 1500. It was the rearmost muffler nearly touching the chassis. Quote Link to comment Share on other sites More sharing options...
Paddy Posted October 19, 2009 Author Share Posted October 19, 2009 Pete, S111 has 2.25 diesel, 90 has 2.5 diesel NA Tycos, I’ve checked the exhaust up front because that’s where I’m sure the noise is from, but I’ll have a look rearward just in case. Quote Link to comment Share on other sites More sharing options...
del Posted October 19, 2009 Share Posted October 19, 2009 I had a rattle on my 2.5l td ,it turned out to be a exhaust bracket that was suppost to be bolted to the engine block,wasnt! Cut a bolt to suit and fixed it back which made the rattle move to a different place Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 19, 2009 Share Posted October 19, 2009 One can spend hours looking for rattles. I had one all the way down to Brighton on the L2B run, turned out it was a stone jammed in the rear bodywork that was causing it to touch the exhaust Quote Link to comment Share on other sites More sharing options...
Paddy Posted October 20, 2009 Author Share Posted October 20, 2009 Hmm the puzzling thing being the identical but worse rattle in the S111. Now having the same in the 90 made me think it was inherent to engine, drive train wear etc. I was waiting for a bit to fall off the S111 so I’d at least know what it had been, but it out lasted me. Guess I’ll just have to wait for the 90 to cure itself with offending bit falling off, I may get lucky and find it when I’m fiddling around. And here’s me thinking I was the only one with a rattle…… Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted October 20, 2009 Share Posted October 20, 2009 I've just cured 2 rattles, one in the back, turned out to be the rear door stay bolts, rusty streaks on the inside of the door was the giveaway,this only took 21/2 years to track down. The other was an irritating dry sweaky rattle from the dashboard somewhere. Again after about 2 years I tracked this down. Had all the dash off etc, wd40, no could't find it. It only happened over 50mph, or going round a roundabout. it turned out to be broken glass from a smashed side window, wedged down in the narrow channel at the top of the dash next to the windscreen, and as it was dry it used to chaf and rubb, on roundabouts and over 50 the air pressure on the screen and the base of the screen caused it to push backwards and trap the glass. So I hooked it all out with a knife, then poured a bit of clean oil down the channel. Ah BLISS!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
nicks90 Posted October 21, 2009 Share Posted October 21, 2009 i have a simillar metallic rattle at very low rpm / labouring the engine - mines a 300tdi. i THINK its the front wing panel flexing at the bottom where one of the supports snapped when i was refitting the wing after bashing it back in to shape doing some bodywork repair. But it could also be the way the front flexi pipe is designed and causing the ribs to rattle when heavily flexed from teh engine vibrating about. Could also be the airbox rattling, as the little rubber feet it sits on where it attached to the side of the engine are a bit past their best. Maybe the front grill surround panel, as thats been chopped about to fit my winch back close to the radiator - so its lost a bit of structural rigidity. tbh it could be anything, far too many things up front that are badly built on a defender. Quote Link to comment Share on other sites More sharing options...
Paddy Posted October 21, 2009 Author Share Posted October 21, 2009 Thanks Nick some more pointers to check out. As other have said, cure one rattle and you'll hear another. Quote Link to comment Share on other sites More sharing options...
Paddy Posted November 11, 2009 Author Share Posted November 11, 2009 Well success as far as the Defender rattle is concerned. A deformed sprung catch on the air filter housing allowed the 2 halves to rattle against each other. 2 minutes with a pair of pliers and I’m running in stealth mode . As if, but its one less. Quote Link to comment Share on other sites More sharing options...
