hoss1720 Posted November 16, 2009 Share Posted November 16, 2009 I have recently changed my disc drum rear axle for a discovery disc/caliper set up. ive noticed that the rear axle half shafts appear to be a 1piece set up which means that my freestyle alloys fit on the hubs allowing the centre caps to be fitted. I was wondering could I get hold of a pair of rear axle disco shafts and fit them to the front axle allowing the alloys to fit with centre caps. Quote Link to comment Share on other sites More sharing options...
santalars Posted November 16, 2009 Share Posted November 16, 2009 Yop, you can take out the CV's and replace the shafts with one piece driveshafts from the rear axle. You then can drive forward and backward in a straight line in your yard as you will only loose the ability to steer the vehicle But that's the price to pay for shiny centre caps. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 16, 2009 Share Posted November 16, 2009 errr...unless Im reading the post slightly wrong..theres no way on earth you can fit rear half shafts to the front axle - how do you go round corners? The front axle case is shorter to allow for the fitting of the swivels, and the front halfshafts have rather important CV joints in them to allow for it to swivel.... Are you acctually asking is it possible to get front half shafts the same style?? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted November 16, 2009 Share Posted November 16, 2009 I have recently changed my disc drum rear axle for a discovery disc/caliper set up. ive noticed that the rear axle half shafts appear to be a 1piece set up which means that my freestyle alloys fit on the hubs allowing the centre caps to be fitted. I was wondering could I get hold of a pair of rear axle disco shafts and fit them to the front axle allowing the alloys to fit with centre caps. easyest way is to get a disco front axle like i did or you could change CV's and all the shafts Quote Link to comment Share on other sites More sharing options...
Litch Posted November 16, 2009 Share Posted November 16, 2009 This is one of those times when spacers are the most straight-forward option (if you like that type of thing). They will allow you to fit your wheels and retain the centre-caps. Quote Link to comment Share on other sites More sharing options...
JST Posted November 17, 2009 Share Posted November 17, 2009 Hoss - the front axle has a different setup. the shafts run from diff to CV. the CV (inside the swivel at the end of the axle) then has the stud that comes out the end into the drive member (RR slightly different but anyway) so you cant fit shafts all the way through. Quote Link to comment Share on other sites More sharing options...
Briarston Posted November 17, 2009 Share Posted November 17, 2009 easyest way is to get a disco front axle like i did or you could change CV's and all the shafts Sorry for jumping in! So do the Disco cv's fit the 90's stub axles? Have not been able to find out before. (I have all good internals from a Disco axle, no axle case) Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 17, 2009 Share Posted November 17, 2009 Sorry for jumping in! So do the Disco cv's fit the 90's stub axles? Have not been able to find out before. (I have all good internals from a Disco axle, no axle case) No, you need to take the whole stub axle and hub assembly. It is quite a downgrade in strength though. Quote Link to comment Share on other sites More sharing options...
