Cynic-al Posted November 18, 2009 Share Posted November 18, 2009 A friends P38 went into lockdown, ie RCL wouldn't work, electric windows wouldn't work and the car wouldn't start. He got the code from the local land rover dealer which he put in via the key in the door lock, the car now runs and the key fob works again but the windows don't. Any ideas? Quote Link to comment Share on other sites More sharing options...
q-rover Posted November 18, 2009 Share Posted November 18, 2009 HAs he set the windows and sunroof? If not there should be messages in the display saying RHF, RHR, LHF, LHR, Sunrrof not set. Open and close fully all windows and sunroof(one at a time) holding the button down for 3 sec when fully open before closing. Once they are all set, normal operation should resume. Ever thought of reading the user manual? Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted November 18, 2009 Share Posted November 18, 2009 When mine was locked out recently the windows still worked (albeit without one-touch up/down). The one-touch doesn't work until the windows have been reset as q-rover describes. Is that what you mean? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 18, 2009 Author Share Posted November 18, 2009 Hi, no the windows don't move at all. The fuses are ok, haven't looked at anything else! Quote Link to comment Share on other sites More sharing options...
vougese39 Posted November 19, 2009 Share Posted November 19, 2009 i would have the becm fault read you will proberly find that it is the first failings of the becm or a door loom. as for the shut down in locking the fault will be the alarm reciver there is a modified unit available from land rover. if you cannot resync the remote then it is a becm issue Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted November 20, 2009 Share Posted November 20, 2009 as for the shut down in locking the fault will be the alarm reciver there is a modified unit available from land rover. if you cannot resync the remote then it is a becm issue Slight thread highjack - do you have any more information on this (part no. etc.)? Asked Stratstone LR in Solihull about this after mine was recovered there from outside a hospital and they didn't know anything about it. I don't think they see many N reg Range Rovers... Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 20, 2009 Share Posted November 20, 2009 Slight thread highjack - do you have any more information on this (part no. etc.)? Asked Stratstone LR in Solihull about this after mine was recovered there from outside a hospital and they didn't know anything about it. I don't think they see many N reg Range Rovers... YWY500170 (433MHz) There is a Technical Bulletin which covers this, but I don't recall the number. Edit to say It is NOT Bulletin 0063, dated 13/11/02, titled 'Battery goes flat overnight', as this relates to an earlier version of the receiver. Parts numbered ASR1953 and YWY500010 are obsolete. HTH Note that I'm only supplying the number, no-one should assume I agree or disagree with the suggestion that this part will 'cure' the problem described. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 21, 2009 Author Share Posted November 21, 2009 Thanks for all the feedback everyone, his current thought is that the window switch panel has failed, he thinks this caused the lock down. Someone is lending him one to try, will let you know. Just for info there are the range rover recalls here http://www.theaa.com/allaboutcars/recalls/recalls.jsp?modelID=A0&modelName=Range+Rover&makeName=Land+Rover++++++++++++++++++&makeId=C3 Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 23, 2009 Author Share Posted November 23, 2009 Hi all, yes it was the Switch panel, he believes the failure caused the lock down. Thanks all. Quote Link to comment Share on other sites More sharing options...
