neil01 Posted November 22, 2009 Share Posted November 22, 2009 hi guys, Ref my other thread about my boot floor: sorry if this is in the wrong place, and if it is please delete and tell me where to stick it! ( )!!! can any one give me a name of a good/trusted seam sealer to use after welding the boot floor or any other welding cheers. regards, neil. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted November 22, 2009 Share Posted November 22, 2009 I got some brushable sealer in halfrauds a while back, think it was called grey stripe. Seems to do the trick. Make sure you use it in a well ventilated area though . It doesn't react to well with some paints so do a tester first! Quote Link to comment Share on other sites More sharing options...
pinny Posted November 22, 2009 Share Posted November 22, 2009 sikaflex takes a lot of beating but aint cheap failing that a can of underbody sealant brush on plenty once its dry the carpet will cover it and wont be seen ill check my shed to see if i still have some sikaflex,chris. Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2009 Share Posted November 22, 2009 one from here should do the job http://www.consumablesexpress.co.uk/acatalog/Sealers.html Quote Link to comment Share on other sites More sharing options...
mobyone Posted November 22, 2009 Share Posted November 22, 2009 sikaflex, without doubt is fantastic. besides, it is for marine applications and so is fine even with loads of of water/salt/pretty much anything. well worth the money..... however is readily availible in other brand names. just search for polyurethane. bondaseal rings a bell too. cloned stuff is probably fine. just remember whichever sealant you use, clean the area thoroughly with meths or acetone and not white spirits so it sticks as it should to metal not grease. richard Quote Link to comment Share on other sites More sharing options...
