geoffbeaumont Posted April 14, 2006 Share Posted April 14, 2006 Fired up the EDIS for the first time today - was a bit disappointed by the spark (still better than the original ignition gives), until it occurred to us that the wasted spark coils probably wouldn't work properly without and earth on either end - stuck another lead and plug on and I now have sparks that reliably jump a good three inch gap Way too much advance at the moment, so I need to take the crank position sensor bracket off and modify it to allow more adjustment. Once I've got it sitting nicely on ten degrees BTDC in limp home mode I can hook it up to the real spark plugs and get it running the engine Then I can start playing with the megasquirt end of things. I'm liking this EDIS thing... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 15, 2006 Share Posted April 15, 2006 Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm You have a PM Geoff Nige Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 15, 2006 Author Share Posted April 15, 2006 I'm afraid I might have got slightly carried away in my enthusiasm last night...the sparks are only jumping a (good) inch today... Still...sparks as never seen before under the bonnet of my rangie Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 16, 2006 Author Share Posted April 16, 2006 Piccies here Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 16, 2006 Share Posted April 16, 2006 Geoff - noticed you are looking for a way of triggering the ECU in the absence of a normal coil, replacing the coil with a ~100 Ohm resistor should work (any value from 2 Ohms up to several K Ohms should be OK but the lower values will dissipate a bit of heat). Edited because the diagram I had was EDIS-4 not EDIS-8, D'Oh! Edited again because I found this one: You'll need to expand this circuit (two extra 1n4004's) to feed all four coils into one TACH signal. If you need diodes I have squillions Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 16, 2006 Author Share Posted April 16, 2006 I'm not going to build any extra circuitry for mine, seeing I'll be getting rid of the Hotwire ECU just as soon as I find a dead one to butcher for its connector. Nige will be very interested in that, though... Quote Link to comment Share on other sites More sharing options...
02GF74 Posted April 27, 2006 Share Posted April 27, 2006 I'm afraid I might have got slightly carried away in my enthusiasm last night...the sparks are only jumping a (good) inch today... Still...sparks as never seen before under the bonnet of my rangie they are probably tired what was the weather like on the previous day - more moisture in the air perhaps? Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 27, 2006 Author Share Posted April 27, 2006 they are probably tired what was the weather like on the previous day - more moisture in the air perhaps? I think it was more over enthusiasm than the weather - think it was pretty dry both days. Either way it's slightly more impressive than the spark off the dizzy... Quote Link to comment Share on other sites More sharing options...
