Jim1 Posted December 12, 2009 Share Posted December 12, 2009 Is it possible to use the chassis from 300TDI Disco and put a Defender body onto it. How much work involved knowing about body mounts will be defferent, Just need to know about chassis yes can be done / no. ( it can't for friend) Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2009 Share Posted December 12, 2009 Defender chassis is 1. a lot deeper in the sides 2. body mounts are completely different 3, cross members -- gearbox & rear different would be easier to shorten a 110 down to 100inch & the mod the body to fit. Quote Link to comment Share on other sites More sharing options...
Jim1 Posted December 12, 2009 Author Share Posted December 12, 2009 Thanks will need to think abit more Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted December 13, 2009 Share Posted December 13, 2009 Is what Mark Evans did on 'A 4x4 is Born' pretty much the same as what this is talking about? There are a lot of changes that you would need to do but it is possible. As far as I know the Range Rover classic and the Discovery 1 chassis are very similar so this would be a good starting point to see if it is achievable. Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted December 14, 2009 Share Posted December 14, 2009 i guess the problem is if you change the chassis in any way you have to get a sva test Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted December 16, 2009 Share Posted December 16, 2009 i guess the problem is if you change the chassis in any way you have to get a sva test I was under the impression that you only need a SVA test if you replace the chassis. Quote Link to comment Share on other sites More sharing options...
disco_al Posted December 16, 2009 Share Posted December 16, 2009 I was under the impression that you only need a SVA test if you replace the chassis. no, it will need an IVA if the chassis is modified in any way Quote Link to comment Share on other sites More sharing options...
