foggy3061 Posted January 2, 2010 Share Posted January 2, 2010 Can anyone help with part numbers for the following items: The white plastic threaded ring that screws onto the TD5 52mm gauges to hold them in place on the speedo panel. Also, part numbers for the O rings that sit around the gauges and the speedo to allow the gauges a little ‘give’ but also prevent them shaking loose. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 2, 2010 Share Posted January 2, 2010 The white plastic threaded mounting ring for the TD5 52mm gauges is STC4641, priced @ £7.43 each The 'O' Rings for the speedo or the 52mm gauges aren't listed. . Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted January 3, 2010 Author Share Posted January 3, 2010 The white plastic threaded mounting ring for the TD5 52mm gauges is STC4641, priced @ £7.43 each The 'O' Rings for the speedo or the 52mm gauges aren't listed. . Excellent, thanks Paul. Will just size up some o rings from somewhere! Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2010 Share Posted January 4, 2010 or from a VDO gauge stockist see orange highlighted info for VDO part number on the attached sheet below No 'O' rings for the gauges listed bt VDO. Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted January 4, 2010 Author Share Posted January 4, 2010 or from a VDO gauge stockist see orange highlighted info for VDO part number on the attached sheet below No 'O' rings for the gauges listed bt VDO. Ah, more info, cheers Western! Just need to gather some O rings now, trip to plumb centre methinkst! Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2010 Share Posted January 4, 2010 happy to help, good luck with the hunt for O rings. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 7, 2010 Share Posted January 7, 2010 O-rings available in various places, like here: http://www.holden.co.uk/displayproduct.asp?pCode=070.040 But if you can find them from a plumbing stockist etc then probably cheaper than ordering online. Quote Link to comment Share on other sites More sharing options...
