disco_al Posted January 7, 2010 Share Posted January 7, 2010 Hi all, Let's put this one out to the general forum guru's and see what we get shall we. Would it be possible to replace the cam driven lift pump with a more reliable electric pump? I can't see any problem to this, apart from getting one with a reasonable flow rate for diesel (which is of course slightly harder to pump tham petrol) My main reason for asking is that my mate's Defender appears to eat lift pumps every six months or so and we can't work out why....... Quote Link to comment Share on other sites More sharing options...
Lars L Posted January 7, 2010 Share Posted January 7, 2010 It can and I have done that on a 2,5 n/a. But more reliable? Quote Link to comment Share on other sites More sharing options...
flatback90 Posted January 7, 2010 Share Posted January 7, 2010 i've and done it on two 200tdi's just ran it thru a relay powered by the stop solenoid wire. Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 7, 2010 Author Share Posted January 7, 2010 that's good to know. any idea what flow rate i would need to use? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted January 7, 2010 Share Posted January 7, 2010 I was just looking into this my self and came across this Pump that say's it can be used as a diesel lift pump. Pete Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted January 7, 2010 Share Posted January 7, 2010 My main reason for asking is that my mate's Defender appears to eat lift pumps every six months or so and we can't work out why....... do the lift pumps come in a blue box? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 7, 2010 Share Posted January 7, 2010 do the lift pumps come in a blue box? Yup, my first thought was about the quality of the pumps! Chris Quote Link to comment Share on other sites More sharing options...
flatback90 Posted January 7, 2010 Share Posted January 7, 2010 that's good to know. any idea what flow rate i would need to use? not a clue! i asked the local motor factors for an electric fuel pump and he handed me one in a quintenn hazell box! Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 8, 2010 Author Share Posted January 8, 2010 no, they don't come in a blue box, lol, they come in a green one. i'm not suspecting the quality of the pumps, as we have tried two different manufacturers to try and eliminate that problem. my suspocion is that it's picking up rubbish from inside the tank, and killing the pumps. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted January 8, 2010 Share Posted January 8, 2010 I use a silver top facet interupter pump with a malpassi filter king pressure regulator and 3 micron filter bowl on my 300tdi. Quote Link to comment Share on other sites More sharing options...
Ruuman Posted January 8, 2010 Share Posted January 8, 2010 I know a few people who have tdi'd their range rovers and just used the standard petrol facet one linked to the standard cam lift pump seems to work fine. Have you taken any of the dead pumps apart to see how their failing? there pretty much the same design since the series vehicles and should be pretty reliable. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted January 8, 2010 Share Posted January 8, 2010 The mechanical pump is merely a plunger driven off the cam lobe. If these are not surviving, surely an Electric Pump isn't going to fare any better at best? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted January 8, 2010 Share Posted January 8, 2010 no, they don't come in a blue box, lol, they come in a green one. i'm not suspecting the quality of the pumps, as we have tried two different manufacturers to try and eliminate that problem. my suspocion is that it's picking up rubbish from inside the tank, and killing the pumps. if it's a disco it should have an inline sedimentor near the A frame inside the o/s/r chassis rail. I believce a genuine pump has a removable top on it, these can be cleaned out easily. The mechanical pump is merely a plunger driven off the cam lobe. If these are not surviving, surely an Electric Pump isn't going to fare any better at best? The stock tdi pump has no filter in it, whereas a facet pump has a gauze to stop carp getting in to it, so at least you can clear it out. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted January 8, 2010 Share Posted January 8, 2010 I believce a genuine pump has a removable top on it, these can be cleaned out easily. That's right, on mine you can even remove the plunger mechanism without physically removing the pump from the engine. The stock tdi pump has no filter in it, whereas a facet pump has a gauze to stop carp getting in to it, so at least you can clear it out. I know the older pumps like on my 2.25 have a sediment filter. Do the mechanical TDi pumps lack this? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 8, 2010 Share Posted January 8, 2010 The pumps I've come across have a small strainer on the inlet to the pump. I've blocked mine a few times. It might be worth a check? Quote Link to comment Share on other sites More sharing options...
