DrRob Posted January 26, 2010 Share Posted January 26, 2010 Will the Disco 200Tdi versions fit a '93 Classic 200Tdi with Borg Warner do you reckon bearing in mind Disco's had a different transfer box? Wide Angle Propshafts Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 26, 2010 Share Posted January 26, 2010 I'd be more concerned about the Disco having the weird 3-prong rubber donut thing on the back and not a standard flange. Quote Link to comment Share on other sites More sharing options...
teslo Posted January 26, 2010 Share Posted January 26, 2010 front ones are different with LT230 and borg warner. So Disco one will not fit RRC with borg warner.( propshaft for Borg Warner have to be longer). Rear ones as FF said...but no big deal to change it. Quote Link to comment Share on other sites More sharing options...
DrRob Posted January 26, 2010 Author Share Posted January 26, 2010 Thanks for info chaps Quote Link to comment Share on other sites More sharing options...
andyb Posted January 27, 2010 Share Posted January 27, 2010 I'd be more concerned about the Disco having the weird 3-prong rubber donut thing on the back and not a standard flange. AFAIK they are only on the '300' Discovery. Quote Link to comment Share on other sites More sharing options...
DrRob Posted January 27, 2010 Author Share Posted January 27, 2010 I'll call them...... Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 27, 2010 Share Posted January 27, 2010 AFAIK they are only on the '300' Discovery. And the softdash RRC. Quote Link to comment Share on other sites More sharing options...
DrRob Posted January 29, 2010 Author Share Posted January 29, 2010 They don't make them...yet.. for Borg Warner fitted Rangies... Quote Link to comment Share on other sites More sharing options...
teslo Posted January 30, 2010 Share Posted January 30, 2010 If you stick with borg warner you will have also problem with crossmember under transmission. you will not be able to use wide angle posibilities of prop because it will touch crossmember( lift front end, let front axle hanging and check it). And when it is not touching crossmember yet, you dont't need wide angle necesarily I have currently in my RRC borg warner with about 2-3 inch lift, +5 inch terrafirma shocks with standard front shock mounts( air suspension version). At front i still have standard propshaft. It is touching crossmember when front axle is hanging on shocks. I am going to change borg warner for LT230. Quote Link to comment Share on other sites More sharing options...
