Sabre Posted January 29, 2010 Share Posted January 29, 2010 Why would a 300 TDi run on after turning the ignition off and the key is removed ? Then it idles for another approx 10 seconds before it stops Would that be a problem with the solenoid ? If so, can the solenoid be fixed, or is replacement the only way out ? Thanks in advance JZ Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 29, 2010 Share Posted January 29, 2010 Stop solenoid most likely. It'll be a replacement, can't say I've done it though. Just remember to be scrupulously clean. Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2010 Share Posted January 29, 2010 remove the stop soleniod & check for slithers of alloy around it's hole in the FIP body, if it's all clear, replace the suspect solly with a new item. Quote Link to comment Share on other sites More sharing options...
patch1 Posted January 29, 2010 Share Posted January 29, 2010 I would also check that there is no voltage at the solenoid after the key is turned off. I've seen in the past voltage leaking through the alternator, through the alt warning light and holding the solenoid open for a while. Just a thought Mark Quote Link to comment Share on other sites More sharing options...
Joe 90 Posted January 29, 2010 Share Posted January 29, 2010 when you take the stop solenoid out, if there is metal swarf on the end of it sorry to say that that will be the end of the road for the injector pump Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2010 Share Posted January 29, 2010 when you take the stop solenoid out, if there is metal swarf on the end of it sorry to say that that will be the end of the road for the injector pump not quite, it can be rebuilt with new internals, had my 200's done a few years ago. Quote Link to comment Share on other sites More sharing options...
evolwood Posted January 30, 2010 Share Posted January 30, 2010 It is also slightly possible that you can still see the swarf slther with the solenoid removed. If this is the case then it may be pulled out with long nose pliers. Way to check if its electrical leakage is just to pull the wire off the stop solenoid when the engine is at idle. If the engine cuts out properly every time then there is no need to remove the solenoid at all. Quote Link to comment Share on other sites More sharing options...
Sabre Posted January 30, 2010 Author Share Posted January 30, 2010 Thanks for all the good advice, looks like I will be busy next week-end Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2010 Share Posted January 30, 2010 to remove the soleniod you'll need a 8mm socket for the electrical spade terminal nut & a moddified 24mm open end spanner for the soleniod body, not much room to swing a full length spanner. Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted January 31, 2010 Share Posted January 31, 2010 to remove the soleniod you'll need a 8mm socket for the electrical spade terminal nut & a moddified 24mm open end spanner for the soleniod body, not much room to swing a full length spanner. Tell me about it, I had a nightmare replacing mine. Thats the trick is it, chop a spanner in half? I replaced mine about 3 or 4 months ago only to have it develope the same problem. I've been stalling now for ages as I can't face the job again . I bought the replacement off ebay was I just unlucky or are some better than others. Sorry to hijack the thread but may prevent someone else making the same mistake. Cheers Chris Quote Link to comment Share on other sites More sharing options...
