tiagoc Posted February 19, 2010 Share Posted February 19, 2010 The engine starter on my standard SIII 2.25D (3 main bearings) seems to be wanting some attention. I was told the starters from the 200tdi are a good replacement for mine, because they are a direct replacement part (no adapting needed) and have more "power" than the Series standard one. Is this true? Has anyone made this change, and able to share some info on the result? Thanks! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 19, 2010 Share Posted February 19, 2010 From what I've heard, yes they are a straight swap. However, a TDi starter has a shorter duty cycle than a 2.25. A TDi starts in the fist few cranks whereas a 2.25 may take several. This can wear out the starter faster. Can't comment on whether this is fact, but I think I read it somewhere. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 19, 2010 Share Posted February 19, 2010 If the 200TDi starter is the same fitting as the 2.5 NA starter, then yes it should fit. I have a 2.5 NA starter on mine. Quote Link to comment Share on other sites More sharing options...
PeterW Posted April 10, 2010 Share Posted April 10, 2010 If the 200TDi starter is the same fitting as the 2.5 NA starter, then yes it should fit. I have a 2.5 NA starter on mine. In that case.... Is the 2.25d starter a straight swap onto a 200TDi...?? Saves me buying one for my conversion if it is.. :-) Cheers Pete Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2010 Share Posted April 10, 2010 2.25 diesel starter, 1st photo don't know if it'll fit a Tdi engine 200Tdi starter,2nd photo Quote Link to comment Share on other sites More sharing options...
Daan Posted April 11, 2010 Share Posted April 11, 2010 Has it 2 bolts? In that case, it wont fit, the tdi or 2.5 d/td have 3 holes on a different pitch. I know that the petrol 2.25 starter wont go on a 2.5 d/td/tdi, but never had a 2.25 diesel myself. Daan Quote Link to comment Share on other sites More sharing options...
PeterW Posted April 11, 2010 Share Posted April 11, 2010 Has it 2 bolts? In that case, it wont fit, the tdi or 2.5 d/td have 3 holes on a different pitch. I know that the petrol 2.25 starter wont go on a 2.5 d/td/tdi, but never had a 2.25 diesel myself. Daan Daan The 2.25D has 3 bolts so I'm good to go I think Cheers] Pete Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 13, 2010 Share Posted April 13, 2010 Tdi starter will fit a 2.25d fine, we were running the very same combo on a 2a. Quote Link to comment Share on other sites More sharing options...
