Briarston Posted May 9, 2010 Share Posted May 9, 2010 Hello computer men! I have a downloaded copy of the earlier Microcat. Running it requires the computer's date/time to be reset. On returning to present time, my anti virus/security system insists on doing a scan and backup apparently fooled into thinking they haven't been done for 4 years. I have downloaded "Runs a date" but now I'm lost! Having spent the first years of my working life using 7 figure log tables these newfangled computer things are still a bit of a mystery to me. Can some kind (and patient!) person please tell me in SIMPLE terms how to make these programmes interact, as I get rather lost with terms such as"applications" "folders" "files" etc! I would be very gratefull for any advice offered. Quote Link to comment Share on other sites More sharing options...
gruntus Posted May 14, 2010 Share Posted May 14, 2010 Hi Briarston, I dont know what version you are using but the best thing is to use a small utility (MCLRE) written which puts your time back, opens Microcat then sets the time back again automatically. I havent ever had a problem with AV or time issues. If you browse through Retroanacondas site located in the post here you can get the downloads from his site. A good rake around should get you what you want. Im not at home at the moment to confirm the details of the utility but someone else maybe able to confirm. Incidentaly if you want to search for things in the forum rather than use the inbuilt search engine (the previous one was better) go to google and enter the following in the search bar: site:forums.lrx4.com +searchnamehere +othersearchnamehere for example searching for an alloy wheel for a 90 you could enter the following then hit search: site:forums.lr4x4.com +alloy +wheel +90 The result will bring you back results and links to the item on the forum. For Microcat you could enter: site:forums.lr4x4.com +microcat +download Hope This Helps. Regards G Quote Link to comment Share on other sites More sharing options...
Briarston Posted May 14, 2010 Author Share Posted May 14, 2010 Hi Briarston, I dont know what version you are using but the best thing is to use a small utility (MCLRE) written which puts your time back, opens Microcat then sets the time back again automatically. I havent ever had a problem with AV or time issues. If you browse through Retroanacondas site located in the post here you can get the downloads from his site. A good rake around should get you what you want. Im not at home at the moment to confirm the details of the utility but someone else maybe able to confirm. Incidentaly if you want to search for things in the forum rather than use the inbuilt search engine (the previous one was better) go to google and enter the following in the search bar: site:forums.lrx4.com +searchnamehere +othersearchnamehere for example searching for an alloy wheel for a 90 you could enter the following then hit search: site:forums.lr4x4.com +alloy +wheel +90 The result will bring you back results and links to the item on the forum. For Microcat you could enter: site:forums.lr4x4.com +microcat +download Hope This Helps. Regards G Thanks very much! I'll do a bit more delving. Quote Link to comment Share on other sites More sharing options...
zim Posted May 15, 2010 Share Posted May 15, 2010 For some reason microlaunch has stopped putting my time correct when i exit microcat ??? G Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 15, 2010 Share Posted May 15, 2010 I have the same trouble Zim Quote Link to comment Share on other sites More sharing options...
hardyspicer Posted May 15, 2010 Share Posted May 15, 2010 Gruntus Thanks for that search tip. I`ve had difficulty using the search with two words in the query. John Quote Link to comment Share on other sites More sharing options...
sasha2001 Posted June 11, 2010 Share Posted June 11, 2010 USE this PROGAm called backdate and set the date inside the program to match the date of you mircocat version and no need to change the computer date http://www.backdate.net/ Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 12, 2010 Share Posted June 12, 2010 Nice one Sasha I've needed to set the time delay to return to correct time to 15 seconds, others may find the same. HTH Mo Quote Link to comment Share on other sites More sharing options...
zim Posted June 12, 2010 Share Posted June 12, 2010 Thanks for the heads up I can't download this for the next week, but is it used instead of microcat or with it ? Cheers G Quote Link to comment Share on other sites More sharing options...
TimR Posted June 12, 2010 Share Posted June 12, 2010 Well I have a genuine licensed June 2010 version of Microcat along with the dongle and I still cant get the bloody thing to work. I have had to install an emulator on windows 7 machine to run XP SP3 which took hours of messing around and it will still only start 50% of the time and that is only if I have one of the CD's in the drive and the dongle plugged in. Bloody ridiculous bit of kit. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 12, 2010 Share Posted June 12, 2010 I have the same trouble Zim AAAAHHAAAAAA!!!! So it's not just me having that problem then. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 12, 2010 Share Posted June 12, 2010 No, not just you Mickey Backdate works a treat Good tip Sacha Mo Quote Link to comment Share on other sites More sharing options...
sasha2001 Posted June 13, 2010 Share Posted June 13, 2010 Thanks for the heads up I can't download this for the next week, but is it used instead of microcat or with it ? Cheers G Install the backdate program and open,select a new profile call it microcat and "point" the backdate program to mclre.exe located in the usually C: mclre folder, tell it that it is a date inside the month of the microcat version you have eg 03/10 tell it the date is say 15/03/2010 and when it opens the exe then microcat always believes the date is that date in the computer even when it is not , sometimes you will get an error on microcat startup saying update wait and it will clear and go through to the program you need of course to use the Crack file mg16.dll from memory and install this Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 21, 2010 Share Posted June 21, 2010 Now using MCAT with Backdate installed and working a treat. Excellent tip Sasha, many thanks. Quote Link to comment Share on other sites More sharing options...
