lapperz Posted May 17, 2010 Share Posted May 17, 2010 hi im trying to remove my half shaft, because ive lost drive on front end,but its properly stuck .ive had mawlgrips on it and everything ,will the diff come off with the half shaft in. cheers Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 17, 2010 Share Posted May 17, 2010 hi im trying to remove my half shaft, because ive lost drive on front end,but its properly stuck .ive had mawlgrips on it and everything ,will the diff come off with the half shaft in. cheers No. However, have you taken the stub axle / swivel assembly off? The CV joint won't come out through the little hole the shaft does. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 17, 2010 Share Posted May 17, 2010 As Errol says, you need to strip the front hub on the offending side down completely so you can remove the half shaft. The tech archive will have a step by step by Uncle Les in it somewhere..... THIS thread should help.... Quote Link to comment Share on other sites More sharing options...
lapperz Posted May 17, 2010 Author Share Posted May 17, 2010 As Errol says, you need to strip the front hub on the offending side down completely so you can remove the half shaft. The tech archive will have a step by step by Uncle Les in it somewhere..... THIS thread should help.... hi ive striped all the hub down ,took the stub axle off but the half shaft is jammed, its loose but jus jammed Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted May 17, 2010 Share Posted May 17, 2010 If persistent waggling etc won't release it then you may have to strip the other side and slide a thin bar through from the other side to knock the half shaft out- the spline is probably twisted in the diff slightly jamming it in. Quote Link to comment Share on other sites More sharing options...
Ex_MOD-90 Posted May 18, 2010 Share Posted May 18, 2010 I had a sheered half shaft a while ago, as Milemarker suggests I had tried the "pushing it out from the otherside" method but the final inch of the spline had twisted and sheered still in the diff so it wouldn't budge. I ended up welding a piece of M20 screwed rod onto the end of the shaft then putting a tube over it (I used a gash length of scaffold pole about 10" long) then slid a large ring spanner onto the rod to act as a stop at the end of the pipe then wound the nut on and used it to draw the shaft out, i was then able to open the diff case and retrieve the last piece that way as due to the twist in the spline it wouldn't come out any other way. I know this sounds quite drastic but I had tried everything else and was sure that the shaft was knackered anyway. Hope this helps as a last resort. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 18, 2010 Share Posted May 18, 2010 Is the swivel straight? Mine needed to be dead straight, and a good 15 stone yank to get them out. Quote Link to comment Share on other sites More sharing options...
