Forcierer Posted May 18, 2010 Share Posted May 18, 2010 Hi, I just wonder if anybody has a hydro assist steering on a Defender TD5? Do I have to drill holes inte the steering box? How are the hoses connected and is the standard pump good (fast) enough? I like to use it mainly for Trophy, but what about fast driving? Is it worth to do it or better investing into a good steering damper? Quote Link to comment Share on other sites More sharing options...
Prith Posted May 18, 2010 Share Posted May 18, 2010 As far as I know its meant only for serious off roading when you have huge tyres. Not for highway driving at all. Quote Link to comment Share on other sites More sharing options...
Forcierer Posted May 18, 2010 Author Share Posted May 18, 2010 As far as I know its meant only for serious off roading when you have huge tyres. Not for highway driving at all. what's the reason? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 18, 2010 Share Posted May 18, 2010 Using the standard pump etc, it will slow the steering down. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 18, 2010 Share Posted May 18, 2010 Hi, Is it worth to do it or better investing into a good steering damper? Hydro steering or a better steering damper are two completely different things. A steering damper makes the steering movement from the steering wheel smoother and hydro steer gives more turning force to the wheels, as said used for when you have larger tyres. I don't think hydro steering is road worthy though. Steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 18, 2010 Share Posted May 18, 2010 I think there was a thread explaining how to connect a LR steering box for hydro assist, I don't think you need to drill anything. Done properly, with a good capacity pump & matched ram, it should be fine. A lot of people do it on the cheap or just throw it together because they don't drive on the highway with it. For strong & fast responding assistance you need a lot more flow than a Rover pump can provide. Quote Link to comment Share on other sites More sharing options...
