rrc 5 spoke wheels
They will fit but you need a 27mm socket for the nuts, but you will need rangerover wheel nuts, as these nuts are deeper which are shaped to fit the wheels, Standard lr wheel nuts will not hold the wheel securely.
hi ralph
thanks for the reply, as in rated do you mean speed or weight loading also i trial fitted one it was a bit snug but did go on the hub but the centre cap on the wheel cannot be used as the end of the hub forced it out
thanks jason
hi ralph
thanks jason
each wheel has a certain weight rating so a pair with sutable tyres will be in excess of the parent vehicles max axle carrying weight & ultimatly it's gross loaded weight, the speed rating depends on what tyres are fitted.
be careful - the wheels do not fit without a little alteration if you have a drum braked Salisbury axle and a front axle with similar hubs - the wheel feels like it fits, but you will see a 3-4mm gap between the wheel and hub mating faces caused by the bevel inside the wheel being closer to the mating face than the bevel on the hubs (near the drive flange gasket). Your options are careful grinding of the hubs, or of the wheels or 4mm spacers with longer (Wolf) studs.
