TheTruckMan Posted July 12, 2010 Share Posted July 12, 2010 as abouv is it worth bidding on think it is only 2 mill thick and the wingtops look rather strange more streight than rounded My link Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted July 12, 2010 Share Posted July 12, 2010 Please resist the temptation Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2010 Share Posted July 12, 2010 the wing tops are the only bits I would use, but the rest is just overkill, those wingtops don't look like the forward end is rolled to match the vehicle panel curve. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 12, 2010 Share Posted July 12, 2010 Are any chequer plate kits any good? Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted July 12, 2010 Author Share Posted July 12, 2010 the wing tops are the only bits I would use, but the rest is just overkill, those wingtops don't look like the forward end is rolled to match the vehicle panel curve. i know i know it is but id probly use most of the kit especialy the sills as there oxadising so bad and looks rubish, the wing tops look funny why are they not a rounded shape like they are on most websites?? Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted July 12, 2010 Author Share Posted July 12, 2010 i rely just want the wing tops/ sills and mabi the corners will not use any of the other parts, but there tempting to bid soo cheap lol Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted July 12, 2010 Share Posted July 12, 2010 I've just fitted a set of chequer plate wing tops over the weekend. Mine were also no rolled at the front, but sit quite nicely just before the roll of the front wing. I did use a pot of black hammerite to paint them with, as I didn't want 'bling' but something to stand on when loading the front of the roof rack! Being alloy the will bend quite easily anyway. Time will tell if I made the right move. Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted July 12, 2010 Author Share Posted July 12, 2010 only thing thats putting me off is they are only 2 mill thick i emaild him and asked as it does not say in the discription, but on the pluss side 2 mill will be much easyer to roll over the edge bit??? Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2010 Share Posted July 12, 2010 IIRC my ones are 2mm thick, got them from Rebel4x4 [before they changed to that name] about 10 years ago, haven't had any problem with the bosdy panel under it bending, use a sealant around the edgeds to keep moisture out & prevent corrosion starting under them. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 12, 2010 Share Posted July 12, 2010 I wouldn't recommend using sealant. A small hole somewhere and there'll be a cavity full of water under the plate. An alloy panel that's held on with alloy rivets to an alloy panel ain't going to rust anytime soon, so I wouldn't even consider that as a potential problem. Les. Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted July 13, 2010 Author Share Posted July 13, 2010 I wouldn't recommend using sealant. A small hole somewhere and there'll be a cavity full of water under the plate. An alloy panel that's held on with alloy rivets to an alloy panel ain't going to rust anytime soon, so I wouldn't even consider that as a potential problem. Les. thanks mate i will keep this in minde whn i eventualy buy some plates Quote Link to comment Share on other sites More sharing options...
