kevin7799 Posted July 20, 2010 Share Posted July 20, 2010 The same old topic of door corrosion - I was told the other day from a landy man with far superior knowledge than I that you can rejuvinate a rotton box section of a door by packing wire mesh into whatever you have left of the box section and fibre glass over it - forming a new reinforced section which will be strong enough to do the job. Being a complete, and I mean a COMPLETE novice, I started looking on the forums and website to see if anyone else has done it but to no avail. Has anyone else done this and to what level of success? - many thanks again, Kevin Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 better to replace the doors or do a proper repair with the correct sectionof material, YRM metal-solutions here lots of other useful repair sections too. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 20, 2010 Share Posted July 20, 2010 The same old topic of door corrosion - I was told the other day from a landy man with far superior knowledge than I that you can rejuvinate a rotton box section of a door by packing wire mesh into whatever you have left of the box section and fibre glass over it - forming a new reinforced section which will be strong enough to do the job. Kevin, Having just read the above I'd question this chaps far superior knowledge ! As Ralph says above cut out the rusty part and weld a new bit in it, it's probably less work than fibreglassing ! Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 20, 2010 Share Posted July 20, 2010 I found an awesome repair on my drivers door I just replaced, it consisted of a kallogs corn flake box section covered in a think super strong covering of body filler. looked ace, hats off to the guy that did it, must have taken him hours. i only found it as I got curious with my hammer, as it looked better than the rest of the door Quote Link to comment Share on other sites More sharing options...
kevin7799 Posted July 20, 2010 Author Share Posted July 20, 2010 many thanks to all, just need to learn how to weld now, happy days! Quote Link to comment Share on other sites More sharing options...
pedro Posted July 21, 2010 Share Posted July 21, 2010 The repair sections look fine. However. They surely do not get around the fact that ali/steel will still always corrode further down the road? My buddy who works with ships reckons he has a solution derived from yacht world, datacouple i think is name. Quote Link to comment Share on other sites More sharing options...
hobson Posted July 22, 2010 Share Posted July 22, 2010 I'm pretty sure LandRovers UK repair them too, cut out the rot and weld in new sections. good company to deal with. they're in Frome, Somerset... Quote Link to comment Share on other sites More sharing options...
