keithjh Posted June 1, 2006 Share Posted June 1, 2006 Hi All, Having installed the 300Tdi+ auto Box from a disco into the 110 and piped it all up, I have fitted the steering box from the disco to give me power steering, need i change the drop arm from the disco box (as long as i use the disco tie bar). Or must i use the 110 drop arm and the 110 tie bar. The reason i ask is the 110 drop arm is not wanting to come off just smashed a 3 leg puller trying. Regards Keith Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2006 Share Posted June 1, 2006 EPC shows 110 drop arm Power steering RTC6398 Discovery upto VIN JA 018109 it's RTC6396 also RR on a manual steering 110 it's STC1044 also used on Discovery upto the VIN noted above hth Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 1, 2006 Share Posted June 1, 2006 Keith I think the anser may be that yes you can use the Disco drop arm and steering bar but you may need to also fit the Disco drag link and damper as the 110 damper will not have a mounting on the Disco steering bar. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted June 1, 2006 Share Posted June 1, 2006 I have a Disco drop arm on my Defender - you use the Disco drag link and a standard ball joint, and I've got Sumo bars with a clamp arrangement to carry the steering damper. You could fit the 110's drop arm instead, but I converted across to get rid of the horrible mud-trap drop-arm ball joint. Quote Link to comment Share on other sites More sharing options...
mwncidur Posted June 2, 2006 Share Posted June 2, 2006 As previously said, the disco drop arm is far more reliable without that stupid droparm mounted ball joint Quote Link to comment Share on other sites More sharing options...
keithjh Posted June 2, 2006 Author Share Posted June 2, 2006 As previously said, the disco drop arm is far more reliable without that stupid droparm mounted ball joint Disco one it is then thanks all. Keith Quote Link to comment Share on other sites More sharing options...
