wellzie Posted September 14, 2010 Share Posted September 14, 2010 Is it possible to remove the pickup body tub to gain access? If so, is it a massive job? I've seen some good responses to other questions on the forum, so I'm looking forward to some good advice Quote Link to comment Share on other sites More sharing options...
western Posted September 14, 2010 Share Posted September 14, 2010 not done it myself, but yes the rear tub can be removed from the chassis. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 14, 2010 Share Posted September 14, 2010 Loads of work to remove the rear tub though. Roof, back door, sides, detach from seat box, wiring, etc, etc. Is it just acces to weld the top? You can cap over so that you actually weld the sides, and extend the repair far enough to be able to weld where the gap is bigger where you have to weld across. If it's within the tub area, then maybe removing the rear floor might be easier. Les. Quote Link to comment Share on other sites More sharing options...
wellzie Posted September 14, 2010 Author Share Posted September 14, 2010 Good advice guys. Les, I think you may be referring to the van type body, wheras mine is the pickup - but thanks anyway. I'll let you know how I get on wellzie Quote Link to comment Share on other sites More sharing options...
KKMobile Posted September 15, 2010 Share Posted September 15, 2010 Not sure if yours will be the same? But on my county when i had to replace rear x member. The guy doing the work asked me to remove the rear floor, This opened up the whole rear of motor exposing all the top of the chassis at the rear. Got to be easier than removing copmplete rear of body?? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 15, 2010 Share Posted September 15, 2010 You'll still have to remove the roof and rear bulkhead panel from the cab, as these attach to the tub. Front edge of the tub also attaches to the seatbox etc as les mentions. Taking the floor out might be the easiest way. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 15, 2010 Share Posted September 15, 2010 It could be high capacity rear tub. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 15, 2010 Share Posted September 15, 2010 It could be high capacity rear tub. Subtitle says its a 90 Quote Link to comment Share on other sites More sharing options...
wellzie Posted September 18, 2010 Author Share Posted September 18, 2010 Unfortunately taking the floor out would have still resulted in some access issues due to the awkward location of the repairs. So, I decided to take the plunge and take the tub out - here's the result : It wasn't as difficult as I thought it was going to be. A few seized-up bolts provided most of the trouble. Although the chassis is in pretty poor repair, its going to be a lot easier to fix now! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 18, 2010 Share Posted September 18, 2010 Job done Mo Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 18, 2010 Share Posted September 18, 2010 Now you've got it that far you might as well take the rest off and drop in a new chassis Quote Link to comment Share on other sites More sharing options...
