Panhard rod - bolt sizes
Grrr...
OK, so I bought the "correct" bolts for the panhard rod and was going to fit them. And they don't fit.
According to the tape, the bolt diameter is just over half-inch. The hole in the bush for the rod is just over half-inch. But, the hole on the chassis is half-inch (exactly, I think). So, bolt fits into rod - but bolt doesn't fit into steering box drop brackety thing.
Pics show the snug-fit of the bolt in the arm - excellent - and it failing to go through the eye in the chassis - tragic.
Yep, it's a hybrid as usual... Any ideas where to go from here ?
Thanks
AW
I seem to remember I replaced one of my bolts, the axle end I think with 1/2" x 3" UNC bolts its a narrow rad arm axle.
I don't have a parts book with me to check, ask Western (Ralph) he should be able to help you with the correct one.
Just found a 110 parts book and it says that both bolts are M14's
My link
My panhard rod is modified one so probably not standard.
Edited by Maverik
Thanks Maverick
I'll check out a couple of M14's tomorrow.. :-)
In the meantime, if anyone else has any thoughts on what's gone wrong here... ?
That said, M14 will be too big for the bushes on the panhard rod itself. Might fit the eyes on the chassis, but....
