madmatt Posted September 29, 2010 Share Posted September 29, 2010 evening all i need to change the brake servo on my 300tdi defender 130, has anyone changed one before? can you give me any hints/ tips or a quick rundown of whats involved? thanks matt Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2010 Share Posted September 29, 2010 replaced my 110's servo a while back, fairly straight forward job, should be able to unbolt master cylinder from servo & move clear without touching the pipework, unbolt servo from pedal housing & pedal lever under dash then extract from engine bay. Quote Link to comment Share on other sites More sharing options...
madmatt Posted September 29, 2010 Author Share Posted September 29, 2010 replaced my 110's servo a while back, fairly straight forward job, should be able to unbolt master cylinder from servo & move clear without touching the pipework, unbolt servo from pedal housing & pedal lever under dash then extract from engine bay. Ralph, you really are the man in the know! that really was the answer I was hoping for cheers! Matt Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2010 Share Posted September 29, 2010 happy to help, hope all fits OK. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 29, 2010 Share Posted September 29, 2010 Yes as Ralph said, it's very easy, just 2 M8 nuts and the vacuum pipe, you can access the end of the pedal through the 2 holes under the big grommets in the sides of the pedal box to disconnect from the pedal. Just be careful to replace or at least preserve the O ring between the master cylinder & the servo. You should get one with a new servo or master cylinder. Regards Nigel Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Share Posted September 29, 2010 I did mine a few weeks ago. Its really easy. The bugger was getting the split pin off the pin in the plunger. Other than that its a 30min job to fit and a simple one person bleed with a Gunnison Easy bleed and a jam jar. However i note you can do it without needing a bleed. Quote Link to comment Share on other sites More sharing options...
JST Posted September 29, 2010 Share Posted September 29, 2010 if you fit a disco servo you get a greater res so better for heavy repeated use - ie offroading an auto for example. (you need to make some new mounting holes for the m/c though Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2010 Share Posted October 6, 2010 continued in this thread http://forums.lr4x4.com/index.php?showtopic=61168 Quote Link to comment Share on other sites More sharing options...
