poohbear Posted October 9, 2010 Share Posted October 9, 2010 Hi all, following last years 200Tdi conversion I think it is about time I finished off the project by re-locating the original TD air filter housing and finally plumbing in the snorkel. Having had a good scrabble around the engine bay and trial fitting the can in all sorts of weird and wonderful places there isn't an easy answer. The original plan means that I have a OS wing top type snorkel already fitted. I have found one solution but it would mean plumbing the can in back to front with the intake and turbo hoses swapped over - My question is would this work? Having looked at the filter I don't think it is likely to collapse or anything silly - would the PCV system clog the filter in this configuration? Thoughts welcome as always. D. Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2010 Share Posted October 9, 2010 the airflow through the filter element would be reversed & it might not filter the incoming air correctly. filters are made so the clean air is drawn from the inner surface then into the engine air intake/turbo. if there's space retain the TD filter housing as it was originally fitted. Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 9, 2010 Author Share Posted October 9, 2010 hmmmm..... only problem being that in the spirit of thriftyness (read 'being a complete tight arse') the first temporary mounting of the filter can used whatever TD/Tdi/Dyson hoses where lying around and required some (read 'all')of the original mounting brackets to be modified (read 'removed'). I'd like to mount it on the inner wing much in the way the 200tdi cabnfits but my washer bottle is in the way! D. Quote Link to comment Share on other sites More sharing options...
crclifford Posted October 9, 2010 Share Posted October 9, 2010 I went down the route of the steve parker kit..ie mounting the air filter where the old TD washer bottle was. Also it messes with the oil dipstick though, which needs to be changed over for a different type, or bent towards the front out of the way...and the kit was very expensive!!! That required the removal of the washer bottle...so i went down the route of a Td5 washer bottle, mounted under the wing at the front. Took a while to find one and fit it though. I had to buy a new loom and refit the correct plugs (econoseal) i think i have a couple left over if you go this route. Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 9, 2010 Author Share Posted October 9, 2010 Kind offer - much appreciated. I have looked at the SP kit but ruled it out due to cost - I think I'll just fabricate a mount and look on flea-bay for the hoses. D. Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2010 Share Posted October 9, 2010 If you still have the TD engine, you'll be pleased to know the dipstick & tube is the same as fitted to the Defender spec 200tdi, so you should be able to re-use the TD parts to get the dipstik clear of any proposed air filter or washer bottle. Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 10, 2010 Author Share Posted October 10, 2010 TD weighed in for cash - nice thought though. D. Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted October 14, 2010 Share Posted October 14, 2010 Here's what I did (not easy to connect to a OS-wing snorkel though...) The filterhouse is a combination of NA and 200 TDI. Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 14, 2010 Author Share Posted October 14, 2010 Very neat set-up. I'm looking for a 90' bend similar to the one you have used to feed the turbo. This should enable me to 'invert' my can much like you have done - That should allow me to run a hose across behind the rad for the snorkel pick up. D. Quote Link to comment Share on other sites More sharing options...
Landy4ducks Posted October 15, 2010 Share Posted October 15, 2010 just another option for you to think about - on my 200tdi conversion the Air filter housing is tucked away under the ns front wing, behind the headlight. see photos[ attachment=32957:Landy air filter 001.jpg] Quote Link to comment Share on other sites More sharing options...
