craig Posted October 11, 2010 Share Posted October 11, 2010 what is the sensor with 2 leads that is on top of a 300tdi? right in the middle of the head bolts? cheers craig Quote Link to comment Share on other sites More sharing options...
western Posted October 11, 2010 Share Posted October 11, 2010 water temp sensor for EGR system Quote Link to comment Share on other sites More sharing options...
craig Posted October 11, 2010 Author Share Posted October 11, 2010 if the egr is removed is this surplus? Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted October 11, 2010 Share Posted October 11, 2010 Yes. Well it had no effect when I removed the EGR on mine! Cheers Peter Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 11, 2010 Share Posted October 11, 2010 can it be re-wired and give some water temp reading thats any better than the normal water sensor on the side of the block ? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 11, 2010 Share Posted October 11, 2010 It might give you a warning when the head looses a bit of water. Quote Link to comment Share on other sites More sharing options...
Davedef90 Posted October 12, 2010 Share Posted October 12, 2010 If you need 1 it's on back order Quote Link to comment Share on other sites More sharing options...
