Jimmy Two-Jacks Posted October 17, 2010 Share Posted October 17, 2010 Sorry more questions.....I recently bought a Britpart (yes I know they are not the best) extended +40mm brake pipe set for my 90 with retro fit td5 axles. Now here is the mystery they sent me four brake pipes two longish and two shorter ones. The thing is I only have one on the rear that conects the front to rear pipe to the T section on the diff that feeds fluid to the calipers via rigid alloy pipes. Perhaps the former owner used rigid pipe instead of flexi pipes to each caliper. Does anyone know where I can buy a single extended brake line to couple the rear axle to the front to back pipe as the two remaining pipes are too short to be used for the job anyway ? Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2010 Share Posted October 17, 2010 rigid pipe to each rear caliper from the T connection, flexy to join T to front/rear rigid pipe. talk to Llama4x4 Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 17, 2010 Author Share Posted October 17, 2010 Many Thanks Cheers James Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 17, 2010 Share Posted October 17, 2010 rigid pipe to each rear caliper from the T connection, flexy to join T to front/rear rigid pipe 4 brake hoses on a TD5 as far as I know - your axles are TD5. What brake hoses did you ask for - TD5 or std 90 ? If you supplied the axle number, then they would have supplied TD5 hoses. Les. Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2010 Share Posted October 17, 2010 Microcat shows NON-ABS rear brakes as one flexible hose to a T connection & rigid pipes to calipers, standard Td5 flexy for rear disc brakes is LR part SHB101370, prior to Td5 it was part NRC9455 for Defender90 models. same numbers if vehicles [td5] have ABS fitted] Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 17, 2010 Share Posted October 17, 2010 Ah - I looked at TD5 Disco, which looks like 4 x flexi pipes to me, although aren't listed seperate from the steel pipes. Les. Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2010 Share Posted October 17, 2010 there's a seperate page in microcat for Td5 Disco2 flexible brake hoses & Yes it has more 4 flexible brake hoses front right 1 x SHB101190 front left 1 x SHB101180 rear right 1 x SHB101200 rear left 1 x SHB101170 & 2 x SHB101350 to take the twin lines to rear of vehicle. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 17, 2010 Author Share Posted October 17, 2010 You guys lost me at "microcat" so thats right then? One flexible to rear T section? Thanks for the replies Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 17, 2010 Author Share Posted October 17, 2010 To be honest I couldnt find a number to quote as these have been shotbalsted and epoxy two pack painted by the original owner (nice job). Where would the numbers be? Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2010 Share Posted October 17, 2010 You guys lost me at "microcat" so thats right then? One flexible to rear T section? Thanks for the replies Microcat was LR's windows based parts system, IIRC it's now called GTR Yes for your 90 one rear flexi at rigid pie to T connector. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 17, 2010 Author Share Posted October 17, 2010 Thanks Ralph. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted October 18, 2010 Share Posted October 18, 2010 The reason there are four hoses in the kit is because they think all Td5's have ABS. ABS axels have two flex pipes going to the rear axle. So it sounds like your set up is correct, but you are very naughty for buying Britpart Andy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 18, 2010 Share Posted October 18, 2010 but you are very naughty for buying Britpart Yes - fit three of them and then beat yourself with the fourth one Les. Quote Link to comment Share on other sites More sharing options...
nino Posted October 18, 2010 Share Posted October 18, 2010 the rear flexy pipe is same lengh as the standard rubber one i got a set of goodridge ones as said a set of 4 the fronts were longer but the rear was the same, i then got some britpart ones again the front was longer but the rear was the same so i got company in high wycomb to make me 3 all +2" than the standard samples and cost about the same as buying a set and they were goodridge pipe and ends Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 18, 2010 Author Share Posted October 18, 2010 the rear flexy pipe is same lengh as the standard rubber one i got a set of goodridge ones as said a set of 4 the fronts were longer but the rear was the same, i then got some britpart ones again the front was longer but the rear was the same so i got company in high wycomb to make me 3 all +2" than the standard samples and cost about the same as buying a set and they were goodridge pipe and ends Thanks for the info any clue as to company? James Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 18, 2010 Author Share Posted October 18, 2010 Yes - fit three of them and then beat yourself with the fourth one Les. Started beating myself but the pipe fell to bits....poor workmanship... Quote Link to comment Share on other sites More sharing options...
nino Posted October 18, 2010 Share Posted October 18, 2010 after spending a wile looking back at my bank statments as i couldnt remember the company as it was a few months back ive found them these people Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 18, 2010 Author Share Posted October 18, 2010 after spending a wile looking back at my bank statments as i couldnt remember the company as it was a few months back ive found them these people Thank you Quote Link to comment Share on other sites More sharing options...
