RAK landy Posted October 19, 2010 Share Posted October 19, 2010 Hi, the rear window on my 2000 3 door soft-top is fully down and refuses to come back up - whether door open, closed, using key or button on console. Any ideas? Also, I need to source a triangular key/tool to undo the soft-top roof triangular studs. Anyone got one I can buy? Quote Link to comment Share on other sites More sharing options...
Disco_Mikey Posted October 19, 2010 Share Posted October 19, 2010 Sounds like the regulator has just died... Quote Link to comment Share on other sites More sharing options...
JonT Posted October 19, 2010 Share Posted October 19, 2010 Check the fuse - I had the same problem on mine earlier this year Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 20, 2010 Share Posted October 20, 2010 Triangular tool is about £5 from the Land Rover main dealer, or there are any number of tool suppliers who will sell you something with the same triangle in the end, it's used on a lot of industrial enclosures etc. Quote Link to comment Share on other sites More sharing options...
theoptimist Posted November 26, 2012 Share Posted November 26, 2012 bit late to the party but, i had this problem, and under the removable canopy on the drivers side there is a switch, that is engaged when the roof is on its about 5mm square, the clip on my roof went so my window was stuck down crammed some wire in there and its now working. Quote Link to comment Share on other sites More sharing options...
paulreeves1975 Posted March 24, 2013 Share Posted March 24, 2013 same happened to me, new reg £40 off ebay, fitted for £50. closes now but i dont use it just in case it goes again! Quote Link to comment Share on other sites More sharing options...
