dirtyninety Posted October 19, 2010 Share Posted October 19, 2010 Just seen this, and I've never seen one with a free spool quite like it clicky linky Quote Link to comment Share on other sites More sharing options...
Warthog Posted October 20, 2010 Share Posted October 20, 2010 Belleview 8000 The Daddy to the Warn8274 Do a web search and thers info out there on them. Also came in a 6000 model too. Quote Link to comment Share on other sites More sharing options...
moose Posted October 20, 2010 Share Posted October 20, 2010 oh dear there goes the hope of getting it cheap... Its a 8200 the missing link between the "Belleview" and the "warn 8274" here is mine... They are gear a bit higher than a standard 8274, have a stronger main shaft (no under cut like the standard 8274), more bearings and with a bow2 on 24v its quite a beast.... but be careful you can not get spares, 8274 bits (apart from the motor drive gear) will not fit it so if you brake some thing you will have the make your self. so you wouldn't want it Quote Link to comment Share on other sites More sharing options...
Warthog Posted October 20, 2010 Share Posted October 20, 2010 I stand corrected Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 20, 2010 Share Posted October 20, 2010 I want it - it's got a fairy lead! Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted October 20, 2010 Author Share Posted October 20, 2010 Your lucky its 200miles from me! Quote Link to comment Share on other sites More sharing options...
Night Train Posted October 20, 2010 Share Posted October 20, 2010 The one I had was even older. Mine only had a band brake on the end and was unidirectional. Quote Link to comment Share on other sites More sharing options...
Mark Posted October 20, 2010 Share Posted October 20, 2010 The one I had was even older. Mine only had a band brake on the end and was unidirectional. That would be a belleview then... Quote Link to comment Share on other sites More sharing options...
