gaz489 Posted October 20, 2010 Share Posted October 20, 2010 basically as it says iv just got my first warn 8274 and im having a bumper made and want to know the size of the bolts i will need??? i will be fitting an ally fairlead too. any advice would be great and a thank you will follow Quote Link to comment Share on other sites More sharing options...
Orange Posted October 21, 2010 Share Posted October 21, 2010 You will need some of these... bolts and some of these: Square nuts as normal nuts don't self-secure in the casing. I think the nearest metric size is M12... Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted October 21, 2010 Share Posted October 21, 2010 Is there not a cheaper option? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 21, 2010 Share Posted October 21, 2010 If someone can tell you the size (It's definitely not metric), you should be able to buy them for pence from a decent nut/bolt/fasteners supplier. Quote Link to comment Share on other sites More sharing options...
gaz489 Posted October 21, 2010 Author Share Posted October 21, 2010 ok so does anyone know the actual size of the bolts? Quote Link to comment Share on other sites More sharing options...
Bush65 Posted October 21, 2010 Share Posted October 21, 2010 The bolts are 3/8" diameter and the square nuts are 3/4" across flats and 3/8" thick. Quote Link to comment Share on other sites More sharing options...
gaz489 Posted October 21, 2010 Author Share Posted October 21, 2010 ooook thanks for the reply will ask my local nuts and bolts place Quote Link to comment Share on other sites More sharing options...
disco2hse Posted October 22, 2010 Share Posted October 22, 2010 Did I hear anyone say high tensile? Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 22, 2010 Share Posted October 22, 2010 Use 3.5 v 8 head bolts same stupid yank thread and work well What my 8274 was fixed to my Arb bumper with They cost about a quid each if that and from memory they come in three different sizes Quote Link to comment Share on other sites More sharing options...
antichrist Posted October 22, 2010 Share Posted October 22, 2010 Did I hear anyone say high tensile? Not really needed for an 8274 mount. All the bolt need to do is to keep the winch from dropping to the ground when you're driving. When winching there's little to no stress on the mounting hardware. Now for winches than mount on the bottom or sides, yes, definitely high tensile. Quote Link to comment Share on other sites More sharing options...
Orange Posted October 22, 2010 Share Posted October 22, 2010 ... want to know the size of the bolts i will need??? ...and from memory they come in three different sizes Am I the only one who sees the funny side of this... Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 22, 2010 Share Posted October 22, 2010 Ok yeah should have said three different lengths Quote Link to comment Share on other sites More sharing options...
disco2hse Posted October 23, 2010 Share Posted October 23, 2010 Not really needed for an 8274 mount. All the bolt need to do is to keep the winch from dropping to the ground when you're driving. When winching there's little to no stress on the mounting hardware. Now for winches than mount on the bottom or sides, yes, definitely high tensile. Oh OK. Just thought I'd ask. So used to people around here getting their knickers in a twist every time someone uses anything other than high tensile on a winch mount of any sort. Quote Link to comment Share on other sites More sharing options...
biggles Posted October 23, 2010 Share Posted October 23, 2010 The ones i used were (In old money) American bolt size SAE (unc) 7/16-14(thread pitch) x 1- 3/4" about 50p each or quid if you want posh cap head allan jobby's rgds Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 23, 2010 Share Posted October 23, 2010 Oh OK. Just thought I'd ask. So used to people around here getting their knickers in a twist every time someone uses anything other than high tensile on a winch mount of any sort. Yeah thats fair enough but also because there are alot of anal toss posts on here who think they know it all but don't :-) Quote Link to comment Share on other sites More sharing options...
