del Posted November 7, 2010 Share Posted November 7, 2010 does antone know were the engine number is on a 200 defender tdi , do i have to tell the dvla of the new engine and number? Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 7, 2010 Share Posted November 7, 2010 Stamped on the block (RHS at the front) next to the fuel injection pump and kind of below the most forward injector. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 7, 2010 Share Posted November 7, 2010 and yes you should tell the DVLA / VOSA Quote Link to comment Share on other sites More sharing options...
del Posted November 7, 2010 Author Share Posted November 7, 2010 Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2010 Share Posted November 7, 2010 should start with 11L*****A in the yellow outlined area, might need a scrub with scothbrite to read it. write the 'new' serial number in the correct part of the V5 & engine capacity 2495cc & fuel type for a diesel is 'heavy oil' not diesel, then send to DVLA & inform your insurance company, they may want a engineers inspection of the installation, just to confirm in writing the install is safe & roadworthy. Quote Link to comment Share on other sites More sharing options...
dmckee Posted January 29, 2014 Share Posted January 29, 2014 The I know this is an old topic - but I hope someone can help me. I have an 93 200TDI. Everything points to this being a standard engine which should be and 11L type engine given the year and model. However, the engine number on the block (usual place below injector #1) looks nothing like a standard engine number. It is RCTDRB1393. I checked the log book and that is the engine number on there too. It only really came to may attention because I need to replace my turbo and found I have the earlier ETC8751 turbo (which belong with a J serial number engine) rather than ETC7461 which is what the the turbo company seemed to expect. Has anyone seen a engine number like mine - it seems likely that someone has replaced the engine block at least - but what it is and where it came from I now have no idea, am a little confused and worried. Having said all that it ran just fine until the turbo seals gave out Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2014 Share Posted January 30, 2014 might be a remanufactured engine, drop a email to Turner Engineering http://www.turnerengineering.co.uk/index.html they might be able to help.it's defo not a LR engine number all 200tdi were 11L or 12L prefix Quote Link to comment Share on other sites More sharing options...
dmckee Posted January 30, 2014 Share Posted January 30, 2014 Thanks Recovery Man, I'll try turner. As you say it has to be a remanufacture - apart from the block it has a standard ribbed aluminium head so looks like a bit of a mongrel. Quote Link to comment Share on other sites More sharing options...
western Posted January 31, 2014 Share Posted January 31, 2014 Your ETC8751 turbo is this one http://www.paddockspares.com/etc8751-turbocharger-200tdi.html a replacement unit, so at some point it's been changed. & is the correct item for a Defender spec 200tdi. ETC7461 is the turbo for the Discovery & RR 200tdi engines so it won't fit the Defender spec 200tdi engine. Quote Link to comment Share on other sites More sharing options...
dmckee Posted February 1, 2014 Share Posted February 1, 2014 Cheers, turbo arrived at the ETC8751 is the correct one (5 bolts to downpipe as opposed to 3 for the 7461). It is just strange that nearly everything in the wagon is original and correct for a 200TDI (11L) engine - most of parts are still original and quite a few have not been changed since new. But the engine block itself (and number) are clearly not kosher. Well it works - or at least it did until the seals on the turbo gave out, so I think I will just quit worrying about it - till I come to sell it at least. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2014 Share Posted February 1, 2014 as the number & V5 match, there's nothing to worry about, I still think it's a reconditioned engine [or maybe just the block] or it came from a stolen vehicle & Police/DVLA have allocated it a unique serial number. you could write to DVLA & get the vehicles registration history for a fee. Quote Link to comment Share on other sites More sharing options...
