ROGUE TROOPER Posted June 18, 2006 Share Posted June 18, 2006 Can I use the EFi 35DLM8 Dizzy when I use carbs or does this have to be a non EFi Dizzy? Ta R Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 18, 2006 Share Posted June 18, 2006 It will be fine. The 35DLM8 is only special in so much as it "feeds" the ECU with a signal. Other than that its fine as a stand alone unit with carbs But why go efi to carbs ??? Nige Quote Link to comment Share on other sites More sharing options...
minivin Posted June 18, 2006 Share Posted June 18, 2006 But why go efi to carbs ??? Nige Richard's been suffering problem's with pinning-down what in the EFi system is causing it to fail, fitting carbs will take the EFi out of the loop and if the problem persists then at least ignition or something else can then be pocked with a stick Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted June 18, 2006 Author Share Posted June 18, 2006 what he said! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 18, 2006 Share Posted June 18, 2006 PM me your e-mail address and if Hotwire or flapper EFI Nige Quote Link to comment Share on other sites More sharing options...
isuzurover Posted June 19, 2006 Share Posted June 19, 2006 Surely it is easier to just go through the full EFI diagnosis procedure, and/or swap bits over from a donor that is known to be working. What exactly is wrong??? Quote Link to comment Share on other sites More sharing options...
minivin Posted June 19, 2006 Share Posted June 19, 2006 Rogues been doing that for three months so far Give it three miles and it then cuts out, give it 15 minutes to cool and it then fires up again. Both ignition and parts of EFi have been replaced, to no evale, so removing one part of the equation will help to pin it down Quote Link to comment Share on other sites More sharing options...
Tomcat Nev Posted June 19, 2006 Share Posted June 19, 2006 But surely removing the EFI is removing more than one thing? I am sure you are getting desperate now going for this course of action but it just seems to be a bit overkill - i have a complete hotwire system sat just up the road from you and you are more than welcome to try it bit by bit to see if you can track down the problem. Cheers Nev Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 19, 2006 Share Posted June 19, 2006 So does it cut out due to lack of fuel or lack of spark? Quote Link to comment Share on other sites More sharing options...
