pete300tdi90 Posted December 2, 2010 Share Posted December 2, 2010 What does this light mean on the dash? It has started to come on when 1st turn the car on, then a min later is goes out...? thanks, Pete Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 2, 2010 Share Posted December 2, 2010 Looks like your brake fluid check light. this does come on when you start the ignition as a check (I think), although it shouldn't stay on. check your brakes for leaks and the fluid level in the resovoir. To check the switch, you can (with the engine running) just remove the resovir cap to the brake servo and it should light up, then when you screw it back down, it should go out. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 2, 2010 Share Posted December 2, 2010 If you mean the yellow one, then I think that is the water-in-fuel warning light. Triggered by the water seperator on the fuel filter, under the offside rear wheelarch on Td5s. Read the owner's manual, it's all in there suprisingly! Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2010 Share Posted December 2, 2010 red light = handbrake on or low brake fluid level amber light = water in fuel, drain the sedimentor on the right rear chassis outer face. Quote Link to comment Share on other sites More sharing options...
pete300tdi90 Posted December 2, 2010 Author Share Posted December 2, 2010 its the water in fuel system, the red one is cos my hand barke is on lol. thanks Quote Link to comment Share on other sites More sharing options...
