steve-c Posted December 15, 2010 Share Posted December 15, 2010 Hi guys and gals.. I cant get my steering wheel off to check but i have a 91plates defender with the origional plastic 4 spoke steering wheel. does any one know how many splines it has..? and any tip on how to get off without having to buy a puller.. cheers Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 15, 2010 Share Posted December 15, 2010 For getting it off, Undo the nut holding it on, but then put it back on a few turns. then Yank to your hearts content Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted December 15, 2010 Share Posted December 15, 2010 I've seen the puller, I'va also seen the price! So I made my own. It's dead easy! A piece of chunky steel and for the crude version, three holes, all un tapped. The outer two bolt it to the wheel, the middle one you can put a nut underneath and with two spanners it's easy to wind the wheel off. (For the posh version, tap the centre hole, do away with the nut and only use 1 spanner!) Cost me less than a £1 and 5 minutes to make! Cheers Peter Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted December 15, 2010 Share Posted December 15, 2010 Original 4 spoke steering wheel on a 91 plate = 36 spline. Quote Link to comment Share on other sites More sharing options...
western Posted December 15, 2010 Share Posted December 15, 2010 What Kev says same as my '89 110CSW's column. Quote Link to comment Share on other sites More sharing options...
