Tom.H Posted December 20, 2010 Share Posted December 20, 2010 Hi I’ve got a 110 TD5 Defender and a weird squealing/machining sound has occurred. I first thought it was an auxiliary belt pulley but it doesn’t occur when the vehicle is stationary or when the engine is rev’d. The sound only occurs when the vehicle is moving and under load. If I dip the clutch and coast the sound does not occur. It occurred after a light green laning trip. My 110 has always had a problem with jumping out of difflock when it’s in a cross axel’d situations. The last lane I did it jumped out of difflock quite harshly. It was used as a tree surgery vehicle before I brought it and I suspect it has been used in low range and difflock a fair bit. It has done 130,000 miles. Because of my greenlining issue and the fact it only occurs under load I believe it’s likely to be an problem with the drive train. Does anyone have any clues?? Cheers Tom Quote Link to comment Share on other sites More sharing options...
del Posted December 20, 2010 Share Posted December 20, 2010 it might be a universal joint on its way out Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 20, 2010 Share Posted December 20, 2010 I'd get under and have a look at the Prop UJ's. (if the snow isnt too deep!) Have a look for slack in them, and if the cups have been spinning in the yokes. Quote Link to comment Share on other sites More sharing options...
dazwell24 Posted December 20, 2010 Share Posted December 20, 2010 I'd get under and have a look at the Prop UJ's. (if the snow isnt too deep!) Have a look for slack in them, and if the cups have been spinning in the yokes. dido landroversforever was too quick for me Quote Link to comment Share on other sites More sharing options...
landy andy. Posted December 20, 2010 Share Posted December 20, 2010 Check the exhaust manifold for warping/broken studs. Just a thought. Andy Quote Link to comment Share on other sites More sharing options...
