mabel Posted January 21, 2011 Share Posted January 21, 2011 (edited) My ABS pump stays running after the engins is switched off. Is this normal? Can anyone offer advice? Edited January 22, 2011 by V8 Freak Added the lower case elements to make this easier to read and no longers appears like SHOUTING.... Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 22, 2011 Share Posted January 22, 2011 Might help if you tell us what kind of landy you have etc........... Quote Link to comment Share on other sites More sharing options...
task Posted January 22, 2011 Share Posted January 22, 2011 My ABS pump stays running after the engins is switched off. Is this normal? Can anyone offer advice? Asuming this is a RRC? how long does it keep running for? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 22, 2011 Share Posted January 22, 2011 It shouldn't run with ignition off, if an RRC. Quote Link to comment Share on other sites More sharing options...
RoaryV8 Posted January 22, 2011 Share Posted January 22, 2011 You sure its the abs pump and not the air compressor? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted January 24, 2011 Share Posted January 24, 2011 Could be a relay that is sticking? Quote Link to comment Share on other sites More sharing options...
zim Posted January 24, 2011 Share Posted January 24, 2011 Could be that your accumulator is no use ? Have a look on rave for diagnosing accumulator problems. G Quote Link to comment Share on other sites More sharing options...
