Souster Posted February 12, 2011 Share Posted February 12, 2011 Hi there, my 90 failed its MOT on the nearside track rod end ball joint. Ive just come to buy a new ball joint and noticed the threads are handed... How do i know which hand thread mine will be? Also, ive heard that the tracking should be checked? Is this the case, even if the centres/threads are measured and the new ball joint is fitted in the same postition? And finally, how difficult is this job, is it one of those awkward ball joints? Many thanks in advance guys, Josh Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 12, 2011 Share Posted February 12, 2011 The ball joints are cheap enough - buy one of each, that's what I do! It's not a too difficult job (if it unthreads without too much persuasion!) Cheers Peter Quote Link to comment Share on other sites More sharing options...
Litch Posted February 12, 2011 Share Posted February 12, 2011 Yes, buy a pair so you know you aren't going to get caught out. That said, are all the TRE's the same age because if you are going to be getting the tracking set I would replace them all so at least you know they are all good? They are not exactly expensive (no more than the cost of having the tracking set) so I would do them all, certainly that is what I have done in the past. I have always found Just Tyres good for doing my tracking, they only charge if adjustment is required (I get it checked every year) and if it needs adjustment they charge about £20. In 11-years this vehicle has only had to be adjusted twice, once after fitting new TRE's and a few years later when I fitted HD rods. Quote Link to comment Share on other sites More sharing options...
zim Posted February 12, 2011 Share Posted February 12, 2011 There will be a jam nut (locking nut) on it tight up against the steering bar, turn this either way till you see it backing off - this'll show you if its a right hand thread or a left hand thread. G Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2011 Share Posted February 12, 2011 There will be a jam nut (locking nut) on it tight up against the steering bar, turn this either way till you see it backing off - this'll show you if its a right hand thread or a left hand thread. G Not on a 90/110/Defender there isn't, the TRE screws into the track rod & it's secured by 2 clamps around the track rod end to close up the split & these clamps are secured by a bolt/nut. see page 462 here Series Vehicles IIRC have locknuts on their steering rods. Quote Link to comment Share on other sites More sharing options...
bm52 Posted February 13, 2011 Share Posted February 13, 2011 This thread reminds me of the pain when i was overhauling my steering and replacing a leaking steering box. The TREs after 13 years where so solidly rusted in the end i bought a new track rod as well. Then everything was easy! Quote Link to comment Share on other sites More sharing options...
