mudmuncher Posted March 13, 2011 Share Posted March 13, 2011 Hi all Right I have a oil leak from the rocker cover gasket on my 300tdi I have replaced the gasket 3 times in the past 6 months and everytime a few days later it's leaking again Any ideas to where I am going wrong I have only been fitting the britpart ones Should I try a genuine one or a smear of instant gasket as well as the standard one ?? Any help or idea will be greatfully recieved Many thanks Chris Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 13, 2011 Share Posted March 13, 2011 I would try another rocker cover. It may have been pulled down too tight. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted March 13, 2011 Author Share Posted March 13, 2011 Would that distort the cover then ? Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted March 13, 2011 Author Share Posted March 13, 2011 Any idea where I can buy a new valve cover all I can find is gaskets ? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted March 13, 2011 Share Posted March 13, 2011 Any ideas to where I am going wrong I have only been fitting the britpart ones I think you may have answered your own question... trying a genuine one may be the quickest and cheapest way to solve it Mike Quote Link to comment Share on other sites More sharing options...
Litch Posted March 13, 2011 Share Posted March 13, 2011 Never had a Britpart one leak, I would go with the distorted cover theory. Have you checked the surfaces to ensure there isn't damage to the mating surfaces, even a slight nick would probably do it? Never had to use sealant of any kind, are you fitting them correctly? Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted March 13, 2011 Author Share Posted March 13, 2011 Hi I will check one I remove it again for damage When I fit them I am making sure they are seated correctly and not over tightening the 3 bolt the manual says a very low torque figure which I am following Not sure it there is anything else I can do Many thanks Chris Quote Link to comment Share on other sites More sharing options...
MUDisGood Posted March 13, 2011 Share Posted March 13, 2011 have had similar problem in past, and make of gasket made no difference. I found that the trick was not to do the naturally right thing. That is some thing leaks with a new seal and to tighten it. I replaced the gasket a number of times and even got a second hand cover and still had the problem. I found the trick is NOT to tighten the cover down all that tight as when its tight down it distorts the gasket. believe me it works! good luck Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 14, 2011 Share Posted March 14, 2011 Can I suggest before getting a new cover, just try it on without a gasket - you should see then if there is any distortion if it doesn't sit reasonably flat without rocking. It might also be a sign of internal pressure - a partially blocked breather perhaps, it doesn't need much to force it everywhere? Does it always leak from the same spot? Nigel Quote Link to comment Share on other sites More sharing options...
