Smokydiesel Posted March 22, 2011 Share Posted March 22, 2011 Hi, About a year ago I finished my "ex-Disco lump into 1985 Defender 90"- conversion. In general I'm very happy with the result, except for the vibrations I have to put up with especially after a cold start. Windows and doors are shaking like crazy, it all dies down a bit once the engine is warmed up but the rattling is always there (on idle-speed). I've tried about everything: new genuine mountingrubbers, endless fidling with the idle-speed, soft radiator/intercooler hoses etc etc. Nothing is rubbing against the body or chassis but still..... Every now and then I read about people having the same problem (but without a cure) Every now and then I read about people having no problems at all. Now I've been told that 200 TDI's tend to vibrate a bit more compared to for instance a 2,5 NA. But so many 200 TDI-Defenders once left the factory rattle-free, why can't mine be like that ? Thanks for any reply Edwin Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 22, 2011 Share Posted March 22, 2011 Mine rattles a bit sometimes when I start up but nothing like what it seems yours is doing. Mine is a Defender 200Tdi though, and the original engine for the truck. I would be interested to know if this makes a difference. What oil do you have in the engine? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted March 22, 2011 Share Posted March 22, 2011 Does it still have the Disco ancilliaries? what gearbox etc. Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted March 23, 2011 Author Share Posted March 23, 2011 Hi The oil.....15W40 from memory, Castrol I believe. I only swapped the engine over, so gearbox and transferbox are original 90. Could the timing of the injectionpump have anything to do with this ? Thanks Edwin Quote Link to comment Share on other sites More sharing options...
nicks90 Posted March 24, 2011 Share Posted March 24, 2011 yes, if the timing is out it will vibrate like hell with diesel knock! also what engine mounts did you use? Very hard rubber will make a difference, i replaced my worn out engine mounts with some poly versions and it was frikkin AWFUL... so i shelled out and bought some replacement genuine rubber from a dealership (not as expensive as you think) and the idle vibrations went away. Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted April 8, 2011 Author Share Posted April 8, 2011 Hi I'm about to fit a new set of mountingrubbers (again) this time from Glencoyne. Let's wait and see...... Thanks, Edwin Quote Link to comment Share on other sites More sharing options...
steve b Posted April 8, 2011 Share Posted April 8, 2011 Hi , is the crank pulley in good condition ? this has a rubber element which is part of the vibe dampening , also did you use the Tdi flywheel? and finally the IP timing is critical and too much advance will increase vibes and diesel knock. My 200 Tdi conversion on my 109 is disco derived incl the Disco engine/chassis mounts - a much better mount system imo and is smooth once warmed up hth Steveb Quote Link to comment Share on other sites More sharing options...
