Muddy 1 Posted May 15, 2011 Share Posted May 15, 2011 Hi Guy's Finally getting along with my Squirting my Hybrid but having issues controling Idle speed, having removed the PWM and blanked all vacuum pipes and breathers I was still running at 1300rpm with the Idle valve closed, So started checking the plenum and inlet manifold for leaks, by spraying some nasty stuff in the local areas upon spraying around under the throttle body my engine tone changed, ah leak found!! so stripped off the Plenum and the inlet manifold to find the gasket sealant I used hasn't worked at all really, Serves me right from nicking it from work! Cheapest carp you can find must be! So can anyone recomend me a decent high temp sealant for the inlet and plenum chambers, Is Blue Hylomar still as good as it gets? or any thing better? Nick Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 16, 2011 Share Posted May 16, 2011 Blue Hylomar worked for me. Are your mating surfaces in good nick? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 16, 2011 Share Posted May 16, 2011 Wot Bishbosh said ^^^ Hylomar is what is mentioned in the Green Bible. Quote Link to comment Share on other sites More sharing options...
Muddy 1 Posted May 17, 2011 Author Share Posted May 17, 2011 yeah Mating surfaces are all good, but the sealant I used seems to thin in viscosity, and bled through rather than sticking to the surfaces. If Hylomar is in the Green bible then that sounds good enough Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 17, 2011 Share Posted May 17, 2011 Loctite black (sensor-safe) RTV. Quote Link to comment Share on other sites More sharing options...
Muddy 1 Posted May 20, 2011 Author Share Posted May 20, 2011 Ok this is getting frustrating now. Plenum stripped and resealed using hylomar, tickover now at 1100rpm. All vaccuum hoses blanked off except fuel rail T peice and Squirt MAP, Have blanked Fuel rail but made no difference and MAP. Idle screw shut. Pwm removed and hoses blanked. Not had this fault before squirting and only change was to remove the plenum and clean up when squirting. Throw some Ideas at me, as I'm lost? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 21, 2011 Share Posted May 21, 2011 Tight throttle cable, fuel prv hose not connected...? Quote Link to comment Share on other sites More sharing options...
Muddy 1 Posted May 21, 2011 Author Share Posted May 21, 2011 Not throttle flap at all, had cardboard over the throttle body tonight, Prv has been checked and not that. Could this be the Squirt? fueling or ignition? Although it's on nige's base map so shouldn't be to far off. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 21, 2011 Share Posted May 21, 2011 Idle is only controlled mechanically really... What about the engine breathers, have you got them connected up properly? With the correct restrictors? Quote Link to comment Share on other sites More sharing options...
Muddy 1 Posted May 22, 2011 Author Share Posted May 22, 2011 Engine breathers were removed and blanked in this exercise! I have found the cause and feel like a plank whilst the plenum was off first time around I removed the very rotten throttle body heater. Didn't realise one of the mounting bolts for this is a direct hole into the plenum!!! DOH!! How I found it was to use my bee smoker and waft smoke around the engine to see if I could find the draw. Which I did. Now has bolts back in all the holes and lots of sealant around all of them!!! I have control of my engine again! Watch the squirt thread for my build pages! Thanks Nick Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 22, 2011 Share Posted May 22, 2011 Good news The other trick is a match or a lighter and watch where the flame gets drawn to, clearly when there are no fuel leaks Quote Link to comment Share on other sites More sharing options...
