chadler Posted July 16, 2006 Share Posted July 16, 2006 Land rover content: Application is a fire-fighting trailer towed behind a fleet of Defenders.... I wonder if any of you knowledgable folk would be able to point us towards a supplier of high pressure hose extensions, as used on petrol pressure washers. I'll attach some pics of the hose endings, hopefully it is a BS standard fitting. the hose is marked 3000 psi normal / 9000psi burst. is a 50 metre extension feasible, or would there be a problem with pressure drop? thanks in advance Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 16, 2006 Share Posted July 16, 2006 For a guess try : www.hyphose.com They have a HUGE range of hose stuff ? Nige Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2006 Share Posted July 16, 2006 I would think Pirtek could help too www.pirtek.co.uk Quote Link to comment Share on other sites More sharing options...
white90 Posted July 16, 2006 Share Posted July 16, 2006 there is a bloke on ebay who sells all things like this I got a drain cleaner from him IIRC Valtech was the company Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 16, 2006 Share Posted July 16, 2006 I would think Pirtek could help toowww.pirtek.co.uk Pirtek did my hose when i buggered up the end. it was a screw on fitting, but they recognised it straight away as a pressure washer one. Quote Link to comment Share on other sites More sharing options...
MogLite Posted July 16, 2006 Share Posted July 16, 2006 I've got exactly the same lance. It melted the tube when it got a bit too close to the pressure washer exhaust. Hyphose cut out the damaged section and repaired it with a couple of screw together metal fittings, so they know what they are doing with the tube. Quote Link to comment Share on other sites More sharing options...
