3.9V8 cutting out
DrRob
Mate's J plate has started cutting out at slow speeds. Wait 5min and it fires up again.
Any thoughts???
Used to have the following in the past. Engine just died and after a few mins started again perfect running. problem was with the electronic ignition module when warm. I replaced it and is ok.
  • 2 weeks later...
  • 3 weeks later...
Bitter experience has taught me that you should be very methodical and check very wire and conector on the ignition side first. I had a similar problem which turned out to be a faulty amp. Always replace with genuine part from franchised LR dealer NOT from fleabay!!! The thing to double check before replacing the amp is the wiring,on one occasion I missed a loose connector to the low tension side and that gave your symptoms.
