tonko007 Posted June 8, 2011 Share Posted June 8, 2011 HI ALL Hi looking to buy a rr p38 have seen an automatic in pristine condition at the garage down the road. the thing is i know nothing about automatics its on a s plate with 109k with full service history and only 3 owners from new what should i be looking for an it many thanks paul Quote Link to comment Share on other sites More sharing options...
task Posted June 9, 2011 Share Posted June 9, 2011 I found this to be of use when I was looking; http://www.mez.co.uk/p38.html Quote Link to comment Share on other sites More sharing options...
barriesheene Posted June 14, 2011 Share Posted June 14, 2011 Anything that is wrong with mine ! 1) lack of power, ( check the kick down ) 2) Wont run on gas 3) coolant in drivers side footwell 4) rain pouring in on passengerside footwell 5) dicky key fob 6) only one key fob 7) suspension works as it should and that the car isnt lop sided 8) warnings on the dash that only show when the key is inserted but not started. If he's keen to start the car for you then thats why ! 9) All electrics work included all seats etc, If theres a button then press it 10) sagging head lining 11) major oil leaks. Check for signs of recently being cleaned. 12) Give the brakes a good stomp Any more I'll post as I find them Quote Link to comment Share on other sites More sharing options...
barriesheene Posted June 14, 2011 Share Posted June 14, 2011 Oh, and the tell tale glue marks on the windscreen from the auction number sticker ! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted June 15, 2011 Share Posted June 15, 2011 Plenty of P38s out there - if it isn't spot on then walk away. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 15, 2011 Share Posted June 15, 2011 HI ALL Hi looking to buy a rr p38 have seen an automatic in pristine condition at the garage down the road. the thing is i know nothing about automatics its on a s plate with 109k with full service history and only 3 owners from new what should i be looking for an it many thanks paul P38s the main thing apart from what has been said is the 4.6 v8 engine was particulary prone to slipped liners if overheated/not looked after. Plenty on ebay with "needs head gasket" or "uses water" "overheats" "loses water" do your home work and it should be ok if it has been looked after (regular coolant changes and radiator in top nick with ample cooling. Be suspicious of bodged repairs Replacement blocks are available but pricey, for a short engine which then needs rebuild. Quote Link to comment Share on other sites More sharing options...
