R380 Gearbox
one of these:
LandRover R380 Gearbox Filler Plug Socket
Item Code: DF472
Shipping Costs
Print this page
Tell a friend
Ask us a Question
This Torx insert and 1/2' drive integral Socket is essential for removing the Gearbox Filler Plug on Land Rover’s R380 5 speed manual gearbox as fitted to Defender’s, Discoverys and Range Rovers.
£3.40 (£3.99 inc.VAT)
Quantity Required
Telephone orders welcome: 0845 125 9407
If you have a Defender, Discovery or Range Rover fitted with an R380 5 speed manual gearbox (on R380 5 speed boxes reverse gear is below 5th gear) then you should replace the Fluid within every 24,000 miles.
However you’ll need this Torx insert and integral Socket to undo the filler plug since it is a special Torx fitting.
This tool is a compact 55mm overall length to permit easy access in the confined space between chassis rail and gearbox.
It can be used also with a Torque Wrench to ensure that the Filler plug is not overtightened when refitting.
The socket is manufactured from hardened and tempered Chrome Vanadium Steel and fitted with an S2 Silicon Steel Torx Bit.
